• Recent Posts
    ranulf
    Machine shop with steam engine
    That video is super cool tho. The detail, the motion....
    I vantz vun......
    ranulf Today, 03:53 PM Go to last post
    ranulf
    :l: Best post ever.
    ranulf Today, 03:49 PM Go to last post
    wombat457
    TECO Train Show
    It sounds like you had a good crowd then and that is the important thing. I agree, seeing kids at a show is a positive thing and being respectful of
    wombat457 Today, 08:22 AM Go to last post
    el Gato Gordo
    TECO Train Show
    Thanks. He wasn't so bold as to actually pick it up. He simply touched the throttle graphic, which started the train. This train is on a branch line,
    el Gato Gordo Today, 08:17 AM Go to last post
    wombat457
    TECO Train Show
    Glad you had a good weekend and everything went smoothly for you but am a bit amazed that someone would simply pick up, and start playing with, your tablet
    wombat457 Today, 01:52 AM Go to last post
  • Brick yard office - scratch building in cardstock - progress and how-to guide.
    Continuing from the previous post, the roof has simply been covered in a metal roofing texture, and the rear of the front wall has had a strip of card and painted brick texture applied.
    http://i1303.photobucket.com/albums/...psmyponewp.jpg
    For the next part of the guide, I'll touch upon the similiar - though different - method used on large doors, in this instance a roller shutter.
    For this, cut diagonally down from each of the two top corners, but only go 1cm or so. from here, cut vertically down from the ends of each cut, then horizontally linking the two together - this will remove excess texture paper from the centre of the newly created tabs...
    http://i1303.photobucket.com/albums/...psxt6fige8.jpg
    ...fold and glue them back just like you would with the windows.
    The next stage is to apply the roller shutter door, front doorway, and a small open window.
    http://i1303.photobucket.com/albums/...psaczk3ihl.jpg
    Apply the door and the roller shutter exactly how the windows were done earlier.
    For the open window, take two identical small window textures, and simply glue them back to back, creating a double sided texture paper. Apply a bead of white glue along the top edge of the window and press it into place at an angle, protruding out from the window frame.
    http://i1303.photobucket.com/albums/...psar03n4pl.jpg
    http://i1303.photobucket.com/albums/...psgqp3hdoc.jpg
    Moving onto the front of the roof, card and texture paper needs to be added to the sides, as well as the top to form capping stones.
    For the sides, card was glued in place, over which small rectangles of Union Hotel Brick texture paper was added - the white edges of this paper was coloured with a dark brown Sharpie, to stop the white edges ruining the illusion of the texture papers.
    http://i1303.photobucket.com/albums/...pshoislmky.jpg
    The capping stones were made by printing out a sheet of N scale Sidewalks with Square Corners texture paper, and trimming it down like this:
    http://i1303.photobucket.com/albums/...psbnbltf89.jpg
    Comments 2 Comments
    1. Valinor2's Avatar
      Valinor2 -
      Thanks for the article. A friend of mine just introduced me to using card stock with model railroading but in a much larger scale. I appreciate seeing it done in N and the possibilities it opens up for the layout I am working on.
    1. sid's Avatar
      sid -
      neat gave me some inspiration
