Results 1 to 17 of 17
Thread: Build an inexpensive paint booth
    Mar 2006
    General area of central Alabama, Birmingham
    Icon6 Build an inexpensive paint booth
    Paint booths are expensive 200 to 600 dollars. Even some of the build it your self projects can run into 100 dollars. Also you made need some skills (electrical) or tools (saws) you don't have and just be a PITA to build.
    I just ran across a DIY paint booth for a cost of about 56 dollars (English Pounds). It looks easy to build using a see through plastic storage box. Well let give you the link. It has excellent instruction and a bunch of pictures showing the parts needed and the build process.
    You may want to Check it out and see what you think. Here's the link;
    http://www.militarymodelling.com/new...cle.asp?a=3661#
    It looks so easy that a no thumbs like me might be able to build it.
    See ya
    "Men go and come,
    but earth abides." Ecclesiastes 1:4
    Hidden Content
  2. The Following 9 Users Say Thank You to 69Z28 For This Useful Post:
    Plantation, Florida, USA
    Ron, is this a candidate for the Links Directory?
    Cheers! Bryan C
    Alligator Lines, "The Eclectic Line of the South"
    Layout web site: Hidden Content
    Personal Blog: Hidden Content
    Hidden Content Hidden Content
    It should probably be obvious from context, but for those who don't speak the King's English, "2 or 3-core flex" is 2- or 3-conductor household wiring... the flexible (stranded) sort used for appliance cords, not the solid-core stuff used for in-wall installation.
    Nice how-to there. Took me just a minute to figure out how to get the other pictures to show, but very good. I suppose a piece of plastic or wood fitting to allow the exhaust hose to be vented out a window while closing off the rest of the open window would be a nice finishing touch...
    Check out the Hidden Content , Hidden Content and Twitter feed (Hidden Content )
    Ride the real thing at the Hidden Content !
    My Electronics Projects: Hidden Content
    Hidden Content
    Lake Charles,LA, USA
    if you build this, be sure to make note of the warning at the bottom of the page.
    The fan used in the article is NOT appropriate for a spray booth because it will spark. You actually should use a fan where the motor does not sit inside the air stream. (We don't want anyone to blow themselves up....)
    Barnegat Light,NJ
    a good but more expensive fan is one for bilge blowers on boats. they are explosion proof.
    Here is a cheap one:
    http://www.amazon.com/SeaChoice-4-Li.../dp/B000N9O7NO
    Here is an explanation of use on a gasoline powered boat so if it will safely remove gasoline vapors it should work fine for a spray booth:
    http://www.boatus.com/boattech/bilgblo.htm
  7. The Following 4 Users Say Thank You to epumph For This Useful Post:
    Feb 2007
    Deer Lodge, MT
    It's interesting you brought this up. I have been gathering "stuff" to build a homemade spray booth. There was a thread from a few months ago I ran across again to inspire me. The fan is probably the most expensive part of the whole project but I am fortunate enough to work at a grocery store where old cooler fans abound. I just need to wire them correctly with some help from an electrician friend of mine and put the rest in place.
    I would really like to see if anyone has made any of these. I'm sure there are members out there that would like to see them.
    When I get done with my mountain I am going to attempt to build one.
    Thanks for sharing this.
    Eric
    Deer Lodge, MT
    You are what you think.
    Hidden Content
    Gene! That is an excellent idea!! That is the biggest falling down point in all fo the home made spray booths is the blower. Sparking is usually not a huge issue but the squirrel cage blowers are fairly expensive. The bilge blower is a great additional piece of info... and inexpensive too!
    Mar 2006
    We can add it to the links directory. I'll do it sometime today.
    And thanks for the additional comments.
    See ya
    "Men go and come,
    Hidden Content
    Mar 2006
    BryanC, added link, awaiting approval.
    See ya
    "Men go and come,
    Hidden Content
    Approved and added!
    Cheers! Bryan C
    Aug 2009
    I've seen the tote box booths,but I wonder how well they will hold up ? I'm sure it weights alot less then mine,big plus is they let in a massive amount of light !!
    L
    SCOTLAND FOREVER !
    Anyone can model prototypically,it takes a genius to model "What If"
  14. #12
    Aug 2009
    Ok just got back from looking at the posted link,now I'm WORRIED !!!!!!!!!!!!!! great build but god man this guy isn't even using a filter system !!!!!!!!!!!!!!!!!,if you ask me that is looking for trouble at least i'm running a double filter before the fan posting the link to my build to refresh being that we'er on the subject.
    L
    http://www.nscale.net/forums/showthr...I.Y-spraybooth
    SCOTLAND FOREVER !
  15. #13
    Feb 2007
    Deer Lodge, MT
    nmanica,
    Your original thread is what inspired me to build one. As I stated earlier I am going to try to follow your example as best I can....it looks like it works great. I will post my progress when I get started in a couple of weeks.
    Eric
    Deer Lodge, MT
    Hidden Content
  16. The Following User Says Thank You to aroc For This Useful Post:
  17. #14
    Aug 2009
    Thank you very much, make sure you check out Wiz's build as I posted picture's of mine after it was build ! Wiz posted pictures as ge was building it. But be warned and please read the disclaimer !
    L
    SCOTLAND FOREVER !
  18. #15
    Nov 2010
    Quote Originally Posted by nmanica View Post
    nmanica,
    Could you re-post the photos that you attached to that thread? I confess that I am not able to use any form of spray paint myself, but I think that this would be of great interest to a friend of mine!
  19. #16
    Mar 2006
    BTW: In his commentary he does suggest adding a filter as well as warning about sparking. Which he claims is a low level risk with a light use model spray paint booth.
    If I build this I would add a multi stage filtering system. And see about upgrading the blower motor. These changes may then send the build costs higher and out of the inexpensive range. Which defeats the purpose of the "inexpensive Paint Booth."
    See ya
    "Men go and come,
    Hidden Content
  20. #17
    Aug 2009
    Quote Originally Posted by Sora Rail View Post
    nmanica,
    Hi, you'll need to go to photobucket to view the pictures as I am no longer a member of this group.look for nmaniac
    SCOTLAND FOREVER !
  1. Inexpensive Amp for under table speakers
    By Michael Whiteman in forum DCC
    Last Post: 7th Nov 2010, 02:21 PM
  2. Inexpensive Air Brush Kit - $6.99
    By NH2006 in forum General Rail Discussion
    Last Post: 19th Jan 2009, 10:24 PM
  3. Replies: 19
    Last Post: 5th Dec 2008, 07:42 AM
  4. Still needing a roof for Booth Kelly Lumber
    By ddavidv in forum Structures & Scenery
    Last Post: 6th Sep 2005, 01:55 PM
  5. toll booth
    By sams in forum General Rail Discussion
    Last Post: 18th Feb 2005, 12:31 PM
