Thread: Installing MT Couplers on Atlas Engine
    Sep 2008
    Default Installing MT Couplers on Atlas Engine
    I just bought my first engine.
    It is an Atlas GP-38-2 with decoder installed, and I also looked up and bought the Micro Train coupler conversion kit.
    My question is, Are the instruction supplied with the coupler clear and easy to understand, and I was also wondering, How difficult is it to install the couplers to the engine.
    Aug 2011
    Woodbridge, VA USA
    Default MT couplers
    Which couplers did you purchase? If you purchased the preassembled 1015 couplers, they should go on just fine.
    Capn Vic
    Riding the NS B line from Manassas.
    Sep 2008
    Thanks Capn Vic,
    I did purchase the 1015 couplers.
    They are easy to install. Study the pictures in the blown apart engine diagram. You will see a three pronged clip inserted to hold the coupler in place. Pull this out with tweezers or needle nose pliers. Discard the brass "spring" strip and rapido coupler. Insert the MT coupler so the hole in the mounting box is over the center hole in the engine body and reinsert the three pronged pin with the center pin going through the coupler. Takes longer to type this out then it usually takes to do the operation.
    Aug 2011
    Woodbridge, VA USA
    Quote Originally Posted by Fund899 View Post
    Thanks Capn Vic,
    Just be careful when removing the shell, its easier to add the couplers with the shell off the frame. The band behind the coupler should be adequate to retain the coupler in position once installed.
    Capn Vic
  1. Installing TCS CN in an Atlas GP40
    By ssoysal in forum DCC
    Last Post: 15th Mar 2011, 03:25 PM
  2. Installing DN163 in older Atlas GP-9
    Last Post: 7th Mar 2011, 05:44 PM
  3. Installing MRC 1812 in Atlas GP35
    By rmorris in forum DCC
    Last Post: 20th Feb 2010, 07:43 AM
  4. Replies: 1
    Last Post: 16th Feb 2009, 06:55 PM
  5. Engine Couplers
    By TaltosVT in forum Diesel
    Last Post: 12th Jun 2007, 12:23 AM
