Results 1 to 10 of 10
Thread: Glued shut with paint
    Jun 2015
    Cyberia
    Default Glued shut with paint
    If I want to paint something with movable parts (doors, hatches, couplers) how can I do so without having the paint prevent them from working?
    You can't outrun your own legs.
    Zombie Hill, Vermont
    77 Post(s)
    Quote Originally Posted by uh_clem View Post
    Very carefully! :l:
    Seriously though, if it cane be disassembled paint it, then re-assemble. Otherwise I use a micro paint brush (can find brushes with tiny tips at michaels or any art store)
    Jul 2010
    Westminster, Ca. USA
    Not knowing what you are planning to paint -- I too, would suggest taking the model apart (If possible) - paint - reassemble.
    Wolf
    Dakota, WI USA
    50 Post(s)
    I'll use a car door as an example. Open the car door. Paint the hard-to-see hinged part first, very sparingly. When it's about 2/3rds to 3/4 dry, operate the door gently and carefully to make sure it moves. When dry, check to see that the door is operational. Touch up very sparingly as needed. When the hinged part is completely dry and operational, paint the door edge and door jambs. Check those for fit after paint is completely dry. Might have to sand them a little, lightly. When that stuff is painted and working, paint the sides and most visible parts of the door.
  5. The Following 2 Users Say Thank You to P-LineSoo For This Useful Post:
    Dec 2007
    Tinton Falls, NJ
    36 Post(s)
    You can try this product with a micro brush http://www.microscale.com/Merchant2/...w=&range_high=
    "It's not whats best......It's whats best for you"
    Gary
    Jun 2015
    Cyberia
    What about a sliding door on a boxcar?
    Dakota, WI USA
    50 Post(s)
    I guess I'd remove the door, sand the part that goes in the track so it's just a tad thinner, and carefully paint the car and door separately. I'd avoid painting the door track, no one is gonna see in there. Then when dry, putting the door back on.
  9. The Following User Says Thank You to P-LineSoo For This Useful Post:
    Jun 2015
    Cyberia
    How about knuckle couplers like Micro Trains? I would definitely not want to disassemble them.
    Jun 2015
    Cyberia
    How would I go about removing a box car door?
    Dakota, WI USA
    50 Post(s)
    You have me on that one. I use Kato's and if I had to paint them, it wouldn't be a big deal, as they don't really have any moving parts, per se'. I guess if I were to paint MT's, I'd use a very very fine brush and concentrate on the outsides, because you don't see the insides when they're coupled anyway, and anyone who gets that close to see if the insides are painted is in danger of catching their nose hairs on the roofwalks and causing a derailment!
  1. Replies: 12
    Last Post: 9th Feb 2016, 06:27 PM
  2. Why a long shut down process for a locomotive?
    By coffeeman in forum Class I Railroads
    Last Post: 22nd Apr 2013, 11:46 PM
  3. Are Bachmann Flat Car Loads glued on?
    By Sleeper in forum Rollingstock
    Last Post: 15th Jun 2011, 07:13 AM
  4. Proto Remote Not Shut Down in Train
    By fifer in forum Class I Railroads
    Last Post: 10th Apr 2011, 02:27 AM
  5. Replies: 13
    Last Post: 2nd Jan 2011, 10:03 AM
