Results 1 to 8 of 8
Thread: PLEASE -- Need HELP applying the Boeing 737 decals
    Aug 2010
    DFW, Texas
    Question PLEASE -- Need HELP applying the Boeing 737 decals
    How did you apply the decals to the 737?
    I bought the micro trains set, I wasn't confident enough to put the decals on fuselages, so a let an experienced friend do it. He has had nothing but trouble applying the decals.
    1. He washed the fuselages.
    2. He applied both Micro sol and Micro Set to the decals, and brushed on Micro Set to the area(and some) on the fuselage.
    3. He then slid the decal onto the spot and it immediately stuck, even after applying more Micro set. While trying to adjust the decal, it curled up and couldn't be salvaged; we tried a few common methods.
    4. The second time, we got the wing decal to work, but we had to slide a small part off the paper and align it to where the decal would be placed. I had to hold the decal in place, while pulled the paper from under the decal.
    5. He then tried the windows, but was concerned about the same issue happening again so he cut the windows into three sections.
    6. The middle section went better, but not perfect.
    7. My Friend said the decals were too thin and painted them with a clear coat(acrylic?) while they were still on the paper. He let them dry for 24 hours, but still had trouble getting them to look right.
    8. He mentioned he was going to wax the fuselage to help it.
    Any thoughts? Please help?
    Any way to improve the look of the decals?
    here is the first side done.
    Jerry
    If you haven't broken something along the way, you haven't learned anything.
    Southwest Coast Florida
    He applied Micro Set "before" placing decal??? I wet the area where decal is to be applied with excess water (I use a Q-Tip to reduce larger droplets). Next I place decal, and position it using water droplets as a lubricant. Then I brush with Micro Sol and allow decal to adhere to surface, removing any excess water drops with new Q-Tips, after I have determined decal is in correct position. I brush clean water to remove excess Micro Sol, then apply Micro Set. Wait 24 hours, and apply a clear coating.
    One more thing. I always place model in refrigerator to cool surface for an hour before applying decals. Saw it on a model car how-to video many years ago. Helps reduce tension, and allows decals slide on surface water layer.
    He used an additional coating for thin decals? Did he check for compatibility first? Maybe coating was not compatible with Micro products?
    Aug 2010
    DFW, Texas
    Quote Originally Posted by CHUCKGEO View Post
    Yes. He brushed Micro Set and Micro Sol on the Decal before placing the decal, and then he brushed Micro Set on the Fuselage before the decal and on the decal as he was applying it.
    The picture in the post shows results after the coating.
    Jerry
    Mar 2005
    Why is he brushing micro sol on the decals before applying them? Micro Sol causes the decals to weaken so they call fall into the details.
    zombietown
    yep apply the micro solutions after they are in the correct area, dont before.
    24 Post(s)
    I've never tried any of these products or done much with decals. Thanks (and sympathy) for asking the question, and thanks for all the educational responses.
    Jan 2015
    Florida, USA
    I've always done micro set to prep the area, place the decal then micro sol to finish. The micro sol is designed to make the decals flimsy so they fall into the details.
    Did someone say whitcomb?
    Aug 2010
    DFW, Texas
    Thanks for all the info. I will let you know how it goes.
    Jerry
  1. Painting and Applying Your Own Decals
    By P-LineSoo in forum Modeling Techniques
    Last Post: 14th Jun 2016, 06:01 PM
  2. Applying Decals to plaster?
    By pbechard in forum Modeling Techniques
    Last Post: 19th Nov 2013, 05:58 PM
  3. applying decals????
    By oval4ever in forum Layouts, Design, & Planning.
    Last Post: 17th Feb 2013, 07:52 PM
  4. Tools I use for applying decals
    By oldnslow in forum Tooling
    Last Post: 3rd Nov 2012, 11:51 AM
  5. Applying Decals
    By Jazzbass01 in forum Modeling Techniques
    Last Post: 15th Aug 2010, 12:27 PM
