Results 1 to 20 of 24
Thread: WS Tidy Track Roto Wheel Cleaner
    Dec 2005
    Tri-Cities, WA
    Default WS Tidy Track Roto Wheel Cleaner
    Has anyone tried the WS Tidy Track Roto Wheel Cleaner that came out a couple years ago? If so, do you actually and/or still use it and would you recommend it? I'm thinking about picking one up but want to make sure you guys haven't had anything misfortune with them first.
    Here is what I'm talking about if you aren't familiar (from Woodland Scenics website):
    https://woodlandscenics.woodlandscen...TT4560_f_1.jpg
    Thanks!
    Bronman - "Trains and Legos... you can't have too many of them."
    My Layout Build Thread - The Spokane & Eastern Washington
    "That's what she said!" - Michael Scott, The Office
    "That's just dumb, D-U-M, dumb." - Me.
    Jan 2015
    Florida, USA
    27 Post(s)
    I had one, it worked but it was very poorly constructed. Wires became unsoldered almost instantly and the thing quite literally fell apart
    Did someone say whitcomb?
    Palo Alto, CA
    I have one. It hasn’t fallen apart but half the time I leave it in the drawer and just use a paper towel soaked with 70% alcohol, which seems to work just as well - and without much expense. Perhaps it might be better for more stubborn grime, but I haven’t run into this yet.
    I had one - long since gone in the trash. I just do it the old fashioned way - paper towels over a spare track soaked with alcohol.
    May 2014
    I had one. Worked for a short time and then had to repair it. Broke again. Try the one from Japan. I can't remember the name. Check Hobbysearch. It works well.
    Trey
    Zombie Hill, Vermont
    92 Post(s)
    Quote Originally Posted by danb View Post
    coffee filters work great too and less likely to get stuck between rails etc (although I still somehow manage )
    15 Post(s)
    I just use a square of toilet paper for that.
    Dec 2015
    Prescott, AZ
    I have one. Don't feel it works very well. Also way too short for some of the larger locos & engines, such as the
    FEF 3 (Four Eight Four), and the EMD DD40AX. I wouldn't waste my money again on it.
  9. #9
    Dec 2005
    Tri-Cities, WA
    Thanks for the responses, exactly why I wanted to ask before spending money. No one ever talks about them so I had my suspicions they were junk. I'll figure out something else to buy.
  10. #10
    Dec 2005
    Tri-Cities, WA
    Quote Originally Posted by emaleyiii View Post
    http://www.1999.co.jp/eng/m/10014385
    Is this it?
  11. #11
    Dec 2007
    Tinton Falls, NJ
    36 Post(s)
    I have one I guess I am the lucky one hasn't broken yet
    "It's not whats best......It's whats best for you"
    Gary
  12. #12
    Some of my club members have it and I've used it at shows we go to. It's more convenient than coffee filters that I use at home. So far I haven't heard anything about them breaking.
    The good thing about this is that you can clean both trucks in one action. Just drop it on a straight track and go. It has pickups at the bottom.
    I'll probably end up getting my own.
  13. #13
    Dec 2005
    Tri-Cities, WA
    I've been looking across Google for DIY locomotive wheel cleaners without much success... thoughts?
  14. #14
    Fifer recommends -
    https://www.youtube.com/watch?v=FV6gUkLsm0k
    Trix $58
    This guy recommends alcohol wipes
    https://www.youtube.com/watch?v=WYZrpERhKkg
    This guy uses paper towel and alcohol - good tip on cleaning your hands
    https://www.youtube.com/watch?v=__yHj-XUruU
  15. #15
    I have the Tidy Track and don't like it. I also have the Trix wheel cleaner which may be good for short engines that do not have traction tires. The brass bristles are destructive of rubber tires.
    Like others, I use alcohol and paper towels on my staging track.
  16. #16
    Apr 2010
    Victoria, BC, Canada
    77 Post(s)
    Isn't just laying some damp with alcohol paper towel on the track, running the train, flipping it around, running it again a pretty easy way of cleaning? These special expensive cleaning tools seem to do the exact same thing they just get both trucks at once.
  17. #17
    May 2014
    http://www.1999.co.jp/eng/10321084
    This is the one I got. They also have an N scale version.
    Trey
    This says non-powered, but mine was powered. Can't find it now.
  18. #18
    144 Post(s)
    fwiw I use mine and it does a decent job and is still intact. I put the cleaner on a straight section of track instead of using the wire and alligator clips. should mention that my locos are all 4 and early 6 axles like SD-9's. Don't know if longer locos would be harder on the cleaner.
  19. The Following User Says Thank You to epumph For This Useful Post:
  20. #19
    Quote Originally Posted by Scotian_Huntress View Post
    Fifer recommends -
    Trix $58
    I cringe every time I see someone use that Trix upside down brass brush to clean loco wheels. That will put micro sratches and grooves on your metal wheels which will catch crud when you run the loco. And the damage is permanent. It's similar to using Brite Boy to clean your tracks. Puts micro groves on them and although for the immediate now it works, but you'll end up cleaning the tracks more often due to the groves storing all the crud. Same principle but now on your loco wheels.
    The best surface is a glass smooth surface so it doesn't retain any crud and it's easy to clean.
  21. #20
    Dec 2005
    Tri-Cities, WA
    Quote Originally Posted by baronjutter View Post
    Yup, and for now I am planning to just keep using that method.
    I have $35 in Amazon gift cards though and I'm trying to figure out what to spend it on, so I thought it would be cool to have a locomotive wheel cleaning station set up ready to go at a moment's notice.
    After giving it some thought, I might try to make my own. More likely though I'll never get around to it; seems like my tuits are forever square.
  1. Track Cleaner?
    By gruss in forum Trackage
    Last Post: 22nd Jan 2017, 11:04 AM
  2. Best wheel cleaner for rolling stock
    By JohnBos in forum Rollingstock
    Last Post: 30th Jun 2016, 07:11 AM
  3. WS Tidy Track
    By JohnMD in forum Trackage
    Last Post: 19th Oct 2012, 04:50 PM
  4. Track cleaner fluid vs. track eraser???
    By Bryan in forum Trackage
    Last Post: 8th Mar 2008, 08:20 PM
  5. Track cleaner
    By bassethound in forum General Rail Discussion
    Last Post: 28th Feb 2006, 11:12 PM
