https://www.nscale.net/forums/showthr...ment-tutorials
In this tutorial, I am going to describe the minimal tools and supplies you need to hand lay track, beyond those required for laying flextrack.
For laying flextrack, I expect most of you have the following tools and supplies available:
- A tool to cut the rail (I use a pair of Xuron rail nippers).
- An adhesive to hold the track in place (caulking, carpenters glue, etc)
- A soldering iron (for feeders and rail joiners)
- Wire Strippers (for feeders)
- Small gauge Wire (for feeders)
- Rail joiners
- Solder (for feeders and rail joints)
A set of jewlers files (for cleaning the ends of the rails and high spots on solder joints.)
For hand laid track, you will need the following additional tools:
- 2 or 3 three-point track gauges. You need two for straight track, and 3 for a curve.
- A tie spacing guide. Mine was constructed from an article in Model Railroader. It consists of roughly a foot long piece of 1x3 with a 1/8" square plastruct styrene. The ties are spaced with n-scale 2x12's (from Northeastern Scale Lumber). This gives a tie spacing slightly larger than the Atlas or ME code 55 track I use elsewhere, but much closer than that of Peco or Atlas code 80 track.
https://www.nscale.net/forums/attachm...1&d=1344834174
And the following supplies:
- Ties (for this tutorial, I am using wooden ties from Micro Engineering)
- Rail (for this tutorial, I am using Micro Engineering code 40 rail).
- Pliobond (an adhesive). We'll use this to secure the rail to the ties
- Masking Tape. We will use this to transfer ties from the spacing gauge to the railroad.
The two photographic attachments to this article show all of the hand laying tools and supplies that are not required for laying flextrack.
In part two, I will show how these tools are used to hand lay a short piece of curved track on one of my Free-moN modules.
vBulletin Message
