Wiring a DPDT switch with a Tortoise and 2 LED
by
Published on 15th Jan 2015 07:43 PM
Someone asked me how I wired my DPDT switches to my Tortoises so the LED's on my control panel would change the lighted color. This is my attempt at a tutorial.
You will need , a DPDT switch On-On , 2 LED's 1 red 1 green is what I use, a piece of heat shrink tube and 3 colors of wire.
http://www.janbouli.com/images/DCC_electro/atort1.jpg
Start by soldering 2 short wires to the top 2 connections on the switch.
http://www.janbouli.com/images/DCC_electro/atort2.jpg
Next 2 somewhat longer wires to the middle connections, it doesn't matter if you use other colors but connect them the same way as I did.
http://www.janbouli.com/images/DCC_electro/atort3.jpg
Next cross over the 2 short wires diagonally and solder them.
http://www.janbouli.com/images/DCC_electro/atort4.jpg
Now solder 2 longer wires to the connectors you just crossed over to, making sure the long wire is connected to the corner that has the same color as the middle wire.
http://www.janbouli.com/images/DCC_electro/atort5.jpg
Make sure the long wire is connected to the corner that has the same color as the middle wire. The switch is now wired.
http://www.janbouli.com/images/DCC_electro/atort6.jpg
Let's start with the LED's . I take a piece of wire in a third color for the next step. Push a piece of heat shrink tube over the wire and solder the wire to the long leg of the green led, see
http://www.tonystrains.com/technews/...iring-leds.htm
http://www.janbouli.com/images/DCC_electro/atort7.jpg
Solder the same wire to the short leg of the Red LED
http://www.janbouli.com/images/DCC_electro/atort8.jpg
Cut the wire and mount both in a terminal block.
http://www.janbouli.com/images/DCC_electro/atort9.jpg
Now solder 2 wires to the other legs of the LED, notice I used the blue wires, because these will be connected to the blue wire on the tortoise. Mount these in the other terminal of the terminal block.
http://www.janbouli.com/images/DCC_electro/atort10.jpg
vBulletin Message
