Results 1 to 8 of 8
Thread: Files lost in Transfer- HELP!
    Oct 2009
    Default Files lost in Transfer- HELP!
    I was trying to transfer a bunch of photos from memory cards, to a disk. I burned them on. Some will work, but most won't, and when I open them, they say the file type is not supported.
    -What went Wrong?
    -How Do I fix it?
    16MARVIGJ
    John
    Quitters never win but winners never quit!
    My railroad bridge webpage. http://pegnsean.net/~johnm/index
    check it out!
    Aug 2010
    North Carolina, USA
    Check your settings in your camera. Some digital cameras come pre-set to use RAW configuration, which is the highest/best resolution, but can only be viewed with a RAW-viewer. Of course most cameras give you the software for the viewer, too, but not all do. You can buy third-party programs like Adobe Camera RAW to view them, but in most cases it's easier to just set your camera to a lower res option like 'high quality JPEG'. This will produce perfectly acceptable images if you're going to do things like make 4x6 or 3x5 prints, or even 8x10s. If you want to make huge blow-ups like posters, you may see some image imperfections, but most people don't do that.
    Now as for the RAW images you have but can't see right now... you will need to convert somehow. I would start by seeing if there is any software that came with your camera or available on the mfgrs website to do the conversion for you. Very few companies will leave you high and dry with stuff like that. Their converter won't be as feature-rich as Adobe CameraRAW, but it will probably do what you need.
    C
  3. The Following User Says Thank You to Chessack For This Useful Post:
    Oct 2009
    Well, it came off a $1000 camera, so there is software. I was taking them OFF the card, and putting them ON a disk.
    16MARVIGJ
    John
    check it out!
    267 Post(s)
    Yeah... So if they were stored RAWon the card, they'll still be RAW on the disk. A RAW converter will allow you to convert them to JPG or something
    Google "UFRaw" it's a free tool than can be used alone or with GIMP to convert and process RAW images.
    Aug 2010
    North Carolina, USA
    You haven't lost your images. If you use Windows Explorer and enable file extensions, you will see that the files are there and have some other extension than .jpg. For my Nikon the extension is .NEF... not sure what it would be for other cameras.
    All you need to do is open your camera's conversion software (for Nikon it's ViewNX), and tell it to convert the RAW file to JPG. You'll still retain the original image, but a copy will be made in a format readable by other programs.
    C
    Oct 2009
    Well, there's my project for tomorrow!
    16MARVIGJ
    John
    check it out!
    Oct 2008
    Sun Lakes , Az , USA
    The advantage of raw images is that you can reprocess them to change things like white balance, this could be quite important with model photography.
    53 Post(s)
    Quote Originally Posted by ibm650 View Post
    You can do all that with JPEG as well, but JPEG is lossy compression. This means every time you manipulate an image and save it as a JPEG, you loose some information from the image. RAW images ( and there is more than one kind of RAW image ) is either uncompressed or compressed using a lossless compression algorithm.
    When my wife and i got married, I was amazed at the number of professional photographers who don't understand this. I actually refused to use a photographer who answered no to the "Do you use RAW?" question.
  1. Printing Xtrackcad files
    By REM37411 in forum Software
    Last Post: 28th Jan 2011, 12:33 AM
  2. XtrkCad parameter files for Switch Machines
    By Sleeper in forum Software
    Last Post: 7th Oct 2010, 11:30 PM
  3. is all lost?
    By filfreight in forum General Wiring
    Last Post: 29th Nov 2009, 02:12 AM
  4. layout files
    By taz-n-rr in forum Software
    Last Post: 27th Jun 2008, 06:31 PM
