Page 4 of 4 FirstFirst 1234
Results 61 to 68 of 68
Thread: Combine ZP Focusing / Stacking
  1. #61
    Netherlands
    214 Post(s)
    You are right Matt , but I am talking about photo's of my structure builds , where I want as much in focus as possible from a very close distance 20 - 30 cm. When I want a photo od a very tiny abject and only the object itself should be in focus I use a 90mm Macro lens or even my 70-300 zoom from much further away.
    As long as I can model in N-scale, I know I'm not old
    My Flickr Pages
    http://www.janbouli.com
  2. The Following User Says Thank You to Janbouli For This Useful Post:
  3. #62
    DFW
    Quote Originally Posted by Janbouli View Post
    That I totally agree with. If you are shooting at that distance with a 1:1 reproduction ratio macro lens, then you're shooting a huge DOF "Macro" that you would have to use stacked images in Helicon or similar. While reading this thread, I was under the impression that the Macro stacking software was being used for regular layout shots, where good lighting/strobes/flash, and a high f-stop should more than suffice. While that's something I see being used in some peoples landscape work, I personally feel that stealing the DOF away makes the shot look fishy. But then again, I hate HDR also.
    Matt
  4. The Following User Says Thank You to GNMatz For This Useful Post:
  5. #63
    Zombietopia, Washington
    543 Post(s)
    Quote Originally Posted by GNMatz View Post
    Moose's layout is cramped so moving a way from the objective of any photograph is difficult to impossible. Additionally, lighting is difficult & time consuming to set up for quick & fun photo shots.
    ~ Moose (Co-founder of the Mt. Tahoma & Pacific Railroad, located some where in the Pacific Northwest)
    "Beware the Train of Thought that Carries no Freight..."
    "Reading is for morons who can't understand pictures..."
    Click Here to See Moose's Layout Thread
  6. The Following User Says Thank You to Moose2013 For This Useful Post:
  7. #64
    61 Post(s)
    Sometimes I miss my old pre-autofocus film SLR. The lens barrels had a depth of field scale on it so that you could tell what distances would be in focus at each f stop; moving the far f22 mark across from infinity got you widest possible depth of field outdoors, in this example from about 14 foot to infinity.
    http://www.fineart-photography.com/dofScale.html
    My autofocus Canon lens doesn't even show you what distance the center of focus is set to, much less the DOF edges.
    In any case, consider focusing somewhat farther back than the nose of the loco on you train shots.
  8. The Following 2 Users Say Thank You to NtheBasement For This Useful Post:
  9. #65
    DFW
    Quote Originally Posted by NtheBasement View Post
    Very good point! When you encounter an unforgivable thin DOF, split it in half, front and back to get the widest sweet spot!
    GNR Pitch Fork Pass
  10. #66
    Quote Originally Posted by Moose2013 View Post
    Moose read about photo focusing / stacking so down load Combine ZP ... Moose see what Paul ( @Jack43 ), TD (@TwinDad ) and others have been able to accomplish with this and other software in other threads, so Moose download and try CZP software today.
    Moose have many problems. Moose no understand what is wrong.
    Moose no understand what wrong?
    Nskale no understand what it even is.
    Must look up this "photo focusing / stacking"
  11. The Following User Says Thank You to Nskale For This Useful Post:
  12. #67
    61 Post(s)
    Resurrecting an old thread...
    I tried CombineZP today and got great results first try.
    [IMG][/IMG]
    Note I had to shrink the resolution considerably to post it here, the original is a bit clearer.
    Downloaded from https://combinezp.software.informer.com/ It installed on my Windows 10 box no problem. It left a short cut on my desktop which I used to run it.
    Took pictures using a tripod (must) with my Canon Rebel SLR and a 100mm Canon full frame macro lens because my other lens doesn't zoom in very close. I had to set up the camera about 4 feet from the scene. I set the camera to f22 to get the max depth of field, and used a remote shutter to avoid shake. The camera set the ISO to 400 and the exposure took 0.8 seconds. Focusing first on the closest point, rock lower right, and last on the farthest, rock upper left, I ended up with 7 jpegs. I put these in a separate folder on my laptop.
    In CombineZP's ancient GUI I took a quick look at the help and then selected in order:
    New, and navigated to and selected the jpegs.
    Align and balance used frames was already selected
    GO, this chugged for a while.
    Do Stack, more chugging.
    Saving was a bit weird folder wise but I found the file. Then I noticed the edges were oddly mirrored (hard to describe) so I cropped them out.
    All in I'm happy with the results. Wondering why others did not it may be the nice detail - static grass - provided good targets for the software.
  13. The Following 10 Users Say Thank You to NtheBasement For This Useful Post:
  14. #68
    49 Post(s)
    That looks fantastic - well done you
  15. The Following User Says Thank You to Scotian_Huntress For This Useful Post:
  1. First time using photo stacking
    By mikec6201 in forum Layouts, Design, & Planning.
    Last Post: 4th Feb 2015, 09:30 PM
  2. photo stacking and Linux?
    By zosimas in forum Photography/Videography (Techniques & Equipment)
    Last Post: 20th Jan 2015, 06:56 AM
  3. Helicon focus (stacking software) sale
    By trainboyh16-44 in forum Photography/Videography (Techniques & Equipment)
    Last Post: 28th Nov 2014, 10:30 PM
  4. Combine Kato controller with Bachmann Turnout
    By dstuttgen in forum Trackage
    Last Post: 23rd Sep 2014, 07:50 AM
  5. Focus Stacking - first attempt
    By TwinDad in forum Photography/Videography (Techniques & Equipment)
    Last Post: 2nd Dec 2013, 04:44 AM
