Results 1 to 4 of 4
Thread: How do you attach paper to styrene for n scale awnings?
    Downers Grove, IL, USA
    24 Post(s)
    Default How do you attach paper to styrene for n scale awnings?
    Even those I consider myself an experienced kitbasher, I'm not sure how to attach paper to styrene. For windows I usually use Elmer's stick glue to attach my paper curtains to a styrene clear piece.
    I decided to add awnings to some of my DPM building. I found some great cardstock paper at Hobby Lobby and used my wife's craft scissors to put a 'V' shaped edge on the n scale awning. But, if I just glue the paper on, it probably won't stay on. Any suggestions on how to attach paper to styrene for n scale awnings?
    AT64
    A man either lives life as it happens to him, meets it head-on, and licks it. Or he turns his back on it and starts to wither away. Dr. Phillip Boyce
    CHICAGO!
    292 Post(s)
    Did you cut out something like this?
    If you have smooth flat walls, a glue stick should work on the tabs. But if the surface has any kind of texture good old PVA (Aleene's/Elmer's) will fill the gaps.
    If the canopy is wide then you might need a support wire frame in the center to keep it from sagging.
  4. The Following 3 Users Say Thank You to ChicagoNW For This Useful Post:
    Southwest Gulf Coast Florida
    27 Post(s)
    I use MICRO KRISTAL KLEAR by Microscale Industries. It's a white glue that dries clear. Made for N scale windows, but attaches anything to other things. Plus remove a glued object, and rub the old glue off. Won't damage paint, or clear plastic. Most hobby shops carry it.
