Results 1 to 3 of 3
Thread: Display case for 3x6 layout?
    Sep 2015
    Default Display case for 3x6 layout?
    We are starting to look at doing a simple 3'x6' layout to get our feet wet with the hobby and have an issue with our cat. She smacks the train as soon as it moves so we need to find a way to encase the layout. I was thinking about somehow putting it into a coffee table setup where it will be under glass which will be in a wood frame. I would then encase the display on the sides too so that she couldn't get in there. Has anyone had experience with this issue? Thanks.
    Rosebud
    13 Post(s)
    I've seen coffee table layouts where the layout is enclosed into a draw set up on rollers. That way you can access the layout when needed or shut it and cute through the glass top
    Shannon
    1100 x 2100 (3'7" x 6'10") layout under construction
    My layout planning and construction;
    https://www.nscale.net/forums/showthr...hlight=rosebud
    Apr 2013
    Kansas City, KS
    89 Post(s)
    I would put the cat in another room and close the door. But since that doesn't sound like an option, and you'd like a coffee table layout, have you done a search on this?
    https://www.google.com/webhp?source=...e+table+layout
    Just a thought...
    N-joy!
    Tred - (USN-Ret.)
    Kansas City, KS
    (Sent using @ 1000Mbps)
  1. Display Case
    By Taylure (RIP) in forum General Rail Discussion
    Last Post: 1st Dec 2013, 05:25 PM
  2. Display Case
    By jimr1cos in forum General Rail Discussion
    Last Post: 14th Dec 2012, 08:17 AM
  3. Looking for a small 24-30 long display case to sit on a shelf
    By Sleeper in forum General Rail Discussion
    Last Post: 5th Jun 2011, 08:29 AM
  4. Display Cases
    By aroc in forum General Rail Discussion
    Last Post: 30th May 2011, 10:06 AM
  5. N Scale Display Case
    By Trainster in forum General Rail Discussion
    Last Post: 20th May 2010, 08:20 PM
