Thread: FA1 power
    Nov 2015
    Default FA1 power
    I am new to N scale and just developing my first very small layout. My main motive power is a single FA1 locomotive. It is a Lifelike and so far I have had no problems with it pulling 10 cars. I guess my concern as a rookie would be to burn out the motor.
    How many cars could my FA1 safely pull without concern of excessive motor ware. I realize this is an older locomotive but one of my favs and want it to be be part of my layout for a long time
    Aug 2012
    New Jersey
    Welcome to N scale!
    It may be worth noting that there were two distinct versions of Life-Like FA-1 locomotives, and earlier version from the 90s and a revision from the early 00s. There may be differences in performance between the two.
    It is also worth noting that factors relating to your layout (such as the steepest grade) and the cars being pulled (size, weight, and tracking characteristics) may impact the loading on the locomotive's motor.
    JERSEY CENTRAL LINES -- Road of the Friendly Trains
    Bozeman,MT
    LL locos in general are strong pullers. As Rwerner noted, there are 2 versions of the FA1.......the older version has a plastic frame with lead weights, the newer version has a split frame. They are about equal in pulling power, but the newer version is a much smoother runner. I wouldn't be afraid to pull 20 cars........I have an ABBA set that I regularly pull 100 cars with. As a rule,the wheels on a loco will start spinning before you put enough load on a loco to harm the motor.
  4. The Following User Says Thank You to MRLdave For This Useful Post:
    Titusville, PA
    Quote Originally Posted by MRLdave View Post
    I believe there was only one version of the FA1/FB1, The other version was a FA2/FB2.
    Dec 2012
    Raleigh, NC
    Quote Originally Posted by rrjim1 View Post
    MRLDave is correct. Sold my lastone, or I'd post a pict. There were 2 versions of the FA2/FB2, as well.
    Don
    If you're having fun, you're doing it right.
    This is not a contest.
    Titusville, PA
    Quote Originally Posted by Carolina Northern View Post
    Don
    To my knowledge there has only been one run of FA1/FB1 from life like. Spookshow lists only one FA1/FB1 manufactured in 2000 and it came with the split metal chassis, I own two sets. Now if Life Like manufactured a FA1/FB1 before that I'm sure some of us would love to see them!
    Nov 2015
    The Lifelike FA1 seems to be a good puller. I have had 14 cars behind it with no problems. Not sure I would want to increase that number.
  1. Missing power supply for Kato 22-014 power Pack
    By Sean Barry in forum DC Controllers
    Last Post: 10th Sep 2015, 05:41 PM
  2. Replies: 18
    Last Post: 1st May 2015, 05:03 PM
  3. Power Cab power panel, power supply
    By dittohos in forum DCC
    Last Post: 26th Mar 2013, 02:32 AM
  4. 2 Power Cab cabs on 1 power Cab system?
    By Sean Barry in forum DCC
    Last Post: 8th Sep 2010, 05:48 PM
  5. Replace "toy power packs" -- consider power pack u
    By Cornreaper in forum DC Controllers
    Last Post: 11th Nov 2008, 10:36 AM
