Page 1 of 4 1234 LastLast
Results 1 to 20 of 70
Thread: Weathering, NO airbrush required
    136 Post(s)
    Default Weathering, NO airbrush required
    After seeing several threads on weathering recently, I decided to take a quick break from my track realignment and attack a couple of cars. Only to see if maybe I can help shed some light on how I weather and to put away the notion that an airbrush is NEEDED for weathering. NOT saying it can't be used, but that you don't need one.
    Disclaimers:
    1) While I say "NO" airbrush, I do use one during my process, but that is ONLY to apply a clear flat coat to seal the original factory paint and then to seal each layer of weathering. When I'm finished with the layers I'll also spray a final coat of flat sealer to lock everything into place and to protect it.
    This can ALSO be done using a "Rattle Can" (aerosol can). Any actual paint, powder or chalk will be applied using a brush or sponge.
    2) This is how I do it. This IS NOT the only way to do it. There are a multitude of methods to achieve any desired results. This is what works for ME.
    After getting a couple of my bridges glued up I set them aside and dug out a couple of older MDC boxcars, one light, one dark. These are brand new cars.
    The first thing I did was to give both cars a silver roof. I'm not a fan of colored roofs. I grabbed a bottle of Floquil "Old Silver" that was sitting on the bench. Any silver color will work, it can be Solvent based or Acrylic based, doesn't matter as I will seal it before I begin weathering.
    They already look better.
    Once the paint was dry I gave them both a liberal coat of Dull Coat.
    This does two things.
    1) It seals the factory paint and the new roof paint I applied.
    2) Most importantly, it gives the surface some "tooth" so as to give the paint and the powders or chalks something to grab to during the process.
    This is the Dull Coat I use when I airbrush it on.
    I'll thin it about 30% thinner to 70% Dull Coat so it flows better through my airbrush.
    Now remember, I stated you can ALSO use a Rattle Can in lieu of an airbrush.
    Now I'll let these cars dry overnight, this allows the sealer coat to fully dry.
    Next comes the FADE coat.
  2. The Following 20 Users Say Thank You to Allen H. For This Useful Post:
    Fort Smith, Arkansas
    This should be fun to watch. Thanks for sharing.
    Daniel Dawson
  4. The Following User Says Thank You to Mobile One For This Useful Post:
    Mendota, IL
    Thank you Allen for taking the time to demonstrate this process. Going to definitely try this.
  6. The Following User Says Thank You to migalyto For This Useful Post:
    Jun 2016
    67 Post(s)
    Awesome! Thanks for writing this up, @Allen H.!
  8. The Following User Says Thank You to Metrolink For This Useful Post:
  9. #5
    196 Post(s)
    So maybe I should be getting out my own SBV boxcar and try to follow along...
  10. The Following 2 Users Say Thank You to WP&P For This Useful Post:
  11. #6
    154 Post(s)
    keep this coming!
  12. The Following User Says Thank You to epumph For This Useful Post:
  13. #7
    44 Post(s)
    Thanks Allen, and hopefully this will become and article as well. I've used your technique based on questions you answered for me earlier, and I think it works great.
  14. The Following User Says Thank You to OTFan For This Useful Post:
  15. #8
    Feb 2015
    SE PA
    Thanks for doing this.
  16. The Following User Says Thank You to jimbo.0455 For This Useful Post:
  17. #9
    37 Post(s)
    Ok, you got our attention....we want more pics!
  18. The Following User Says Thank You to dave68124 For This Useful Post:
  19. #10
    136 Post(s)
    OK, on with the second video.
    This one has no music, sorry, just me rambling away for about 28 min.
    Please forgive my oration, it is not my forte and I am not a speaker.
    In this vid I will be showing the application of the Burnt Sienna which will replicate a rusty tone or rusty coat.
    As I say in the video, I am just preparing the base coats for the cars. If you think they look good, you can leave them when you're done.
    If not you can keep going with more layers, more rust build up and add scratches.
    While I'm doing this on Boxcars, this method should work on most other cars as well.
    Some cars like tank cars may need a different type of weathering due to the nature of the car and the use of the car.
    One of my goals here is to show the method that I used to create this car:
    Which is why I'm using the same car and road name.
    A couple of things before hand.
    The white wash effect on the two cars have been sealed and dried. They ready to cover.
    While I use Burnt Sienna, other colors can be used. Even try mixing some colors.
    I chose these colors as my base coats because they are what I was told to use and what I have seen others use, and they have worked for me.
    Certainly there is no reason to stick with these colors, and no reason not to try other colors. Experiment!!!
    Enjoy!
  20. The Following 19 Users Say Thank You to Allen H. For This Useful Post:
  21. #11
    Kingston, Ontario
    27 Post(s)
    This is an excellent technique. Very simple but effective. I'm going to try it this weekend on a grain car
  22. The Following User Says Thank You to ScottL For This Useful Post:
  23. #12
    136 Post(s)
    Quote Originally Posted by ScottL View Post
    Please do @ScottL!
    Then post what you've done please.
    I haven't yet moved away from boxcars fully as there are so many things I've seen that I want to try out before moving on other cars.
  24. The Following User Says Thank You to Allen H. For This Useful Post:
  25. #13
    Mar 2005
    Meridian, New York
    I have never paid attention when in position to look at car roofs but do the full sized box cars have silver roofs ?
    Or do you paint them silver to bring out the color of the weathering ?
    And thanks for making the videos.
    Craig
  26. #14
    136 Post(s)
    Quote Originally Posted by CraigN View Post
    In this case I painted them to help show the weathering. I prefer silver roofs.
    Some are painted and some are not. I would think depends on several things.
    I'm betting they were painted early when costs were not a factor.
    Later with the cost of labor and materials rose, I would guess they just used aluminum or galvanized roofs.
    If you look at the cars from IMRC and/or FVM, some of them came with silver roofs and you can see a trace of overspray paint around the edges of the roofs, which suggests that the roofs were not painted on some cars.
    A lot depends on the customer whether they wanted them painted or not, and the cost associated with it.
    Absolutely!
    I'll be uploading the third one tonight.
  27. #15
    154 Post(s)
    here is a discussion of boxcar roofs:
    http://forum.atlasrr.com/forum/topic...TOPIC_ID=38507
    some interesting stuff
  28. The Following 4 Users Say Thank You to epumph For This Useful Post:
  29. #16
    Kingston, Ontario
    27 Post(s)
    I tried this technique today and I am very pleased with the results. It is rather intimidating to smear paint over a prized car, but the Q-tip method works well and you have a lot of control as to how much you leave on. Oil paints are very forgiving compared to acryllcs.
    This car needed a dirty fade and the first application of burnt sienna looks very good to my eye. I would prefer to weather prior to assembly, but it was not possible with this car.
    Thanks Allen for the impetus to get me to try this. It is easy to do, uses minimal materials, and you really can't go wrong. A great combination!
  30. The Following 5 Users Say Thank You to ScottL For This Useful Post:
  31. #17
    Kingston, Ontario
    27 Post(s)
    Another attempt, this time with burnt umber. I had pre-faded the paint with zinc white airbrushed on and tagged and patched accordingly. This car came from a friend and needed a little TLC, but now it looks down and dirty. The oil paint really helps to blend the graffiti.
    The burnt umber is easy to get too heavy, I think. I felt that way a bit about the examples in your video too, but it might just be my preference. I need to get some white and other colors to see what is possible.
  32. The Following 5 Users Say Thank You to ScottL For This Useful Post:
  33. #18
    136 Post(s)
    Thanks for posting @ScottL!
    Those look real good with just the one coat!
    You're absolutely right, it's a very simple and easy process that gives you lots of control.
    The only drawback is you have to wait a little bit longer for the coats to dry, but I'll gladly give that up in return for the ease of application and the time you get to re-work any spots or areas.
    I really like how you left some of the coat heavy up under the roofwalks. To me that just helps to convey a place where not even mother nature can get it clean.
    Yup, the Burnt Umber can be dark, but like I said, no reason not to try mixing it with a lighter color like white or off white or even a beige? Or even with a color that's close to the original paint.
    No real reason to have to put on multiple colors either, just depends on how you want the car to look. My process is how I plan to weather my entire fleet, but with varying amounts of fade and colors.
  34. The Following User Says Thank You to Allen H. For This Useful Post:
  35. #19
    Kingston, Ontario
    27 Post(s)
    Thanks Allen. I agree, different approaches will give variety and that will look quite natural in a train. I'm going to pick up some white and maybe raw sienna and raw umber. They should be good for dirt, I think. I am also keen to try the fade with white.
    One thing that I found was that this method was very good for making subtle streaks from rust and dirt. These are impossible to do by hand, but they are a natural result of selectively removing paint and keeping some areas with a little more.
    I'm really happy how they interacted with the graffiti. I wanted some fade to the graffiti so it was more subtle and this technique is great for blending.
  36. The Following User Says Thank You to ScottL For This Useful Post:
  37. #20
    Nov 2013
    North Adams, MA - USA
    39 Post(s)
    LOVE THIS THREAD!!!!!!!!!!!!!!! thank you so much for posting it.. I will watch that video more than once I am sure!!
    Thank You,
    Bear
    Read about the Bear Cave Co. Rail Line on Face Book At https://www.facebook.com/BCCRL
    see my adventure unfold here http://www.nscale.net/forums/showthr...ture-Continues
    where we started http://www.nscale.net/forums/showthread.php?31828-Adventures-on-the-BCCRL
  38. The Following User Says Thank You to stampbear For This Useful Post:
  1. EOT - Not Required?
    By musicman in forum General Rail Discussion
    Last Post: 4th Nov 2011, 11:37 PM
  2. Some assembly required
    By dave92029 in forum Steam
    Last Post: 2nd Apr 2011, 07:57 PM
  3. Weathering With Airbrush?
    By 16marvigj in forum Modeling Techniques
    Last Post: 21st Sep 2010, 06:24 PM
  4. Expertise required
    By 0pti0n in forum Layouts, Design, & Planning.
    Last Post: 15th Dec 2008, 08:40 PM
  5. LENZ programming help required
    By seanm in forum DCC
    Last Post: 14th Dec 2008, 08:14 PM
