Results 1 to 4 of 4
Thread: DCC with a DC Locomotive
    Dec 2016
    Grass Valley CA, USA
    Default DCC with a DC Locomotive
    What happens if you try to run a DC locomotive on a track that is powered by DCC?
    Jim
    Nov 2011
    Hermitage, PA
    Depends on the DCC system I think. I know Digitrax is capable of running 1 DC loco under the address 00, but you can't leave it sitting for too long or it'll burn out the motor. The DCC signal makes the DC motor constantly change directions, effectively vibrating at a stop.
    Tim
    Shoot for the stars, anything less and your selling yourself short...
    B&LE SD18 project
    B&LE 200: The Merry Widow
    B&LE SD38AC build
    D&H #17 project
    Resin T-1 build
    246 Post(s)
    This (start at about 5:55)
  4. The Following User Says Thank You to TwinDad For This Useful Post:
    Palo Alto, CA
    25 Post(s)
    I park my few DC locos on a siding that I also use as a programming track, with a center off switch that lets me select between normal DCC, no power or programming. That way, when not running the DC loco, I switch the power for that track off and eliminate the motor hum (and risk of over heating). Not ideal, and I will get around to installing DCC in the rest - except perhaps for my Atlas shay, in which there’s not an easy DCC install.
  1. What is this locomotive?
    By Scotian_Huntress in forum Steam
    Last Post: 1st Mar 2017, 12:29 AM
  2. TP-56 Locomotive
    By DrifterNL in forum General Rail Discussion
    Last Post: 17th Jun 2015, 04:35 PM
  3. Help - what locomotive is this?
    By Tred in forum Diesel
    Last Post: 11th Aug 2013, 02:33 PM
  4. Little Joe 0-6-0 Locomotive
    By treadhead1952 in forum Steam
    Last Post: 5th Feb 2013, 05:17 PM
  5. Looking for a locomotive
    By thirdrail in forum Steam
    Last Post: 18th Aug 2008, 10:17 PM
