Thread: Body-Mounting Kato Superliners
    34 Post(s)
    Default Body-Mounting Kato Superliners
    I'm currently in talks with a Shapeways designer to print a body-mount coupler adaptor piece that goes on the underframe of the Kato Superliner cars. He mainly wants to know what coupler he should design it for. The MTL 1015 is a reasonable standard, but the drawback is that it won't allow for closer coupling of the cars, as the diaphragm gap is something I want to reduce when eventually body mounting these.
    Or could the new True Scale Coupler be the option here?
    Any thoughts?
    Columbia, Missery
    Definitely go TSC... Been test running ten cars and a atlas GP40 on a table with 12-13" curves with little to no problems, only key to that diamater is the coupler boxes have to swivel a little bit. But it does bring the rolling stock much closer together.
    :SFSD75M::SPWELL::TTX::SPWELL:
    DEADPOOL 4 EL PRESIDENTÉ 2016!!
    Follow me on Tumblr!
    http://nscaler711.tumblr.com/
    Jan 2015
    Florida, USA
    47 Post(s)
    If I'm not mistaken both the tsc and 1015 couplerbox are the same in terms of size so they should be interchangeable BUT you could go with a 1015 and an operating diaphragm from American Limited Models:
    http://www.americanlimitedmodels.com...car-set-black/
    Did someone say whitcomb?
    34 Post(s)
    Quote Originally Posted by Intermodalman View Post
    Only the draft gear box are the same in terms of size. The knuckle on the TSC is way smaller than the 1015, and there is no slack action, therefore it will couple the cars closer.
    Also the diaphragms you listed are not the same style as Superliner diaphragms.
    Jan 2015
    Florida, USA
    47 Post(s)
    Quote Originally Posted by MetroRedLn View Post
    http://www.americanlimitedmodels.com...-car-set-gray/ theres the right style and I'm aware the knuckle is smaller, that's the only reason they exist
  1. Body mounting or Truck mounting couplers?
    By JimmyD89 in forum Rollingstock
    Last Post: 21st Feb 2015, 10:28 PM
  2. Kato Superliners on 9 3/4 r track ?
    By mmahoag in forum Rollingstock
    Last Post: 18th Jul 2014, 12:31 PM
  3. Replies: 6
    Last Post: 22nd Apr 2011, 11:29 PM
  4. Kato versus Con-Cor Amtrak Superliners
    By dowish in forum Rollingstock
    Last Post: 18th Jun 2008, 05:09 PM
  5. Body mounting Micro-Trains couplers
    By Catt (RIP) in forum Rollingstock
    Last Post: 22nd Mar 2004, 09:49 PM
