Results 1 to 4 of 4
Thread: Question on Arduino Solid State Relays triggering
    Feb 2017
    Default Question on Arduino Solid State Relays triggering
    I'm running DCC sounded locomotives on a digitrax based loconet, and planning to automate a crossing intersection. My plan is to:
    1. use an arduino mega board & IR detectors to sense trains' arrival at intersection,
    2. drive a low-level triggered solid state relay to generate normal signals + a high-level triggered solid state relay to generate brake signals, via the arduino mega board, to the brake section
    3. use a digitrax booster to handle the brake section signals
    I'd like to know if I can use the SAME output pin from the arduino mega to drive both the low-level & the high-level relays, producing the effect of a SPDT switch. I used mechanical relays in the past. It worked, but its triggering noise was very annoying. On the other hand, solid state relays only support SPST and one has to double the number of relays to create the SPDT effect.
    Many Thanks for your advice.
    45 Post(s)
    Most ( all? ) solid state relays are just LEDs on the trigger side and a phototransister on the output side.
    The Arduino should have no problem driving more than one from a single output.
    For decoder installation and JMRI services, please visit http://www.bentraildigital.com
    For n-scale intermodal information, please visit http://nscaleintermodal.com
  3. The Following User Says Thank You to pbender For This Useful Post:
    Feb 2017
    Thanks pbender,
    Are you saying solid state relays may not be able to handle a booster load of 12.7v at 8A from the Digitrax booster scaled to N?
    45 Post(s)
    Quote Originally Posted by KKL View Post
    All of the ones I have used have been in low voltage circuits, but what it can handle depends on the specific device. I don't know enough about what's out there to provide a good answer to that question.
  1. Relays for DC block control
    By Birdog357 in forum General Wiring
    Last Post: 22nd Feb 2018, 08:57 AM
  2. Solid or Strand?
    By Gryxter in forum General Wiring
    Last Post: 10th Jan 2018, 11:35 AM
  3. Arduino Question
    By emmdom in forum DIY Controllers
    Last Post: 30th Jul 2013, 07:37 PM
  4. Locating 12V DC Relays
    By j3v in forum General Wiring
    Last Post: 6th Nov 2009, 10:30 PM
  5. ALP alternative - Solid Ink
    By in forum Modeling Techniques
    Last Post: 19th Mar 2008, 08:54 AM
