Results 1 to 20 of 37
Thread: Two pylons? Or Three? Help me decide
    Mar 2011
    Windsor, Ontario, Canada
    Question Two pylons? Or Three? Help me decide
    I'm 3D printing a highway overpass that will span the width of my layout. In one section, it crosses three rails and I'm trying to decide which pylon configuration looks the best? Which is most prototypical? I'm curious for your opinions...
    Peter
    Layout Depot (share your designs with others): www.LayoutDepot.com
    My Build Thread: www.nscale.net/forums/showthread.php?28081-Green-Valley-Railway
  2. The Following 4 Users Say Thank You to pbechard For This Useful Post:
    143 Post(s)
    My vote goes for three.
    I think it looks more balanced that way?
    ďNever argue with an idiot. They will only bring you down to their level and beat you with experience." George Carlin
  4. The Following User Says Thank You to Allen H. For This Useful Post:
    Mill Bay BC
    77 Post(s)
    I like the 3 as well for the same reasons Allen does . But highway spans can easily do the 2 pilons .
  6. The Following User Says Thank You to aflica For This Useful Post:
    Jan 2015
    Florida, USA
    34 Post(s)
    Without seeing the rest (say if the bridge was supported by something else) 2 looks unnatural. It'd cost capacity with no real benefit
    Did someone say whitcomb?
  8. The Following User Says Thank You to Intermodalman For This Useful Post:
  9. #5
    Dec 2015
    Chicago, IL
    I vote for two piers, the span doesn't look long enough to need three. Plus those things are really expensive to build, they wouldn't put in a third if they didn't need it.
  10. The Following 3 Users Say Thank You to dwwojcik For This Useful Post:
  11. #6
    Mar 2011
    Here's a pic of the scene in progress. 4' wide part iof the layout. The left end of the bridge will be "floating" near the edge of the layout. The middle part of the roadway will be built on the hilltop (no bridge there). The white foam board surface is temporary to get a sense of what it will look like.
    Peter
  12. The Following 5 Users Say Thank You to pbechard For This Useful Post:
  13. #7
    Chilliwack, BC
    It definitely looks more balanced with three.
    Director of Operations of the Kettle River Railway
    See photos of the original owner's layout here:
    https://m.flickr.com/#/photos/about-...7603977732928/
    It sounded like a good idea at the time... too bad the caboose wasn't in on the plan.
  14. #8
    Dec 2007
    Tinton Falls, NJ
    37 Post(s)
    I think it looks better with three.
    "It's not whats best......It's whats best for you"
    Gary
    Zombie Hill, Vermont
    104 Post(s)
    like what dwe said. maybe find real life prototypes that are similar sized spans?
  16. #10
    Netherlands
    118 Post(s)
    Will the bridge be supported at the abutments , then I think 1 would be the prototypes choice.
    As long as I can model in N-scale, I know I'm not old
    My Flickr Pages
    http://www.janbouli.com
  17. The Following 2 Users Say Thank You to Janbouli For This Useful Post:
  18. #11
    Era plays a role here.
    If this was built in the 1960's, likely 3. They couldn't build steal beams big enough and strong enough for one economically.
    Today, likely 1. Bigger beams are no problem, and it would cut costs to have one in the middle. Heck, depending on span it may be zero.
  19. The Following User Says Thank You to bicknell For This Useful Post:
  20. #12
    Oct 2016
    Barrington IL
    I think 3 looks the best to my eyes. Either way going to be a great looking scene.
  21. #13
    Feb 2011
    Lake Ariel PA
    I say 3. Looks balanced
  22. #14
    30 Post(s)
    Looks vs. prototypical might be at odds here.
  23. #15
    Mar 2011
    Quote Originally Posted by kingmeow View Post
    I think that's my struggle. I like the three, but two is more prototypical.
    Quote Originally Posted by bicknell View Post
    Modern layout, so I can go with either.
    Probably could go zero but I'll need at least one near the edge of the layout to hold up the floating end!
    Quote Originally Posted by Janbouli View Post
    Yes, there will be proper abutments at the hillside.
    The thoughts on "one" are something I hadn't considered. Here's how that looks:
    Peter
  24. The Following 3 Users Say Thank You to pbechard For This Useful Post:
  25. #16
    30 Post(s)
    If you are doing one as Janbouli suggested, I would put it between the two tracks or even to the right of the right most track, not off to one side in your previous picture.
    Another alternative is to check the typical spacing for columns in the era you are modeling (via pictures and other info). Then do some scale mathematics to figure out if you need 1,2 or 3.
  26. The Following User Says Thank You to kingmeow For This Useful Post:
  27. #17
    39 Post(s)
    I think two supports looks best. With 3 pylons the spans seem much too short. With just 1, the depth of the beams doesn't look thick enough.
    I'm very much looking forward to seeing the development of this scene!
  28. #18
    143 Post(s)
    How about sitting a semi truck and/or car so you can judge the size a bit better.
  29. #19
    Mar 2011
    That was my first thought too, but I'd worry about the floating end with that much of a "diving-board" overhang.
    Peter
  30. #20
    104 Post(s)
    Place a "concrete" foundation at the far right end, then I think it would look about right. At least from a Northern New England point of view
  1. You Decide 2012 - My Color Scheme
    By bc6 in forum Diesel
    Last Post: 23rd Jul 2012, 04:30 PM
  2. You decide
    By Phill91 in forum General Rail Discussion
    Last Post: 14th Jul 2012, 03:08 PM
  3. Replies: 21
    Last Post: 24th Dec 2010, 05:38 AM
  4. How the heck do you decide?
    By DesertRat in forum General Rail Discussion
    Last Post: 15th Dec 2008, 04:54 PM
  5. N vs HO dilemma - Can't Decide!
    By Gargoyle in forum General Rail Discussion
    Last Post: 18th Nov 2008, 03:55 PM
