Results 1 to 20 of 34
Thread: Suggestions, Opinions, Advice needed.... help!?!?
    Apr 2011
    Rockhampton, QLD, Australia
    Question Suggestions, Opinions, Advice needed.... help!?!?
    Hi everyone, I am currently looking at a space under the house for a layout.
    Dimensions can go up to 7' x 16' so it is somewhat sizeable.
    The only thing is that I am having trouble designing a track plan for such a size.
    I have only really ever done HCD sized stuff... 7x3 etc.
    So I am just wondering if anyone has any ideas on how or if I can incorporate the following...
    Double main (if possible)
    At least a 4 track yard
    2-4 small industrial spurs
    River/Bridge
    Two towns represented... (plan on running CNW and BNSF most prominently)
    I will be running a variety of trains, Passenger and freight, long and short and the track will be flex track C55.
    Pretty much any design I have made thus far just ends up in a paperclip shape like a sideways "U"
    Seeing as I don't have a whole lot of time most weeks to design, I was hoping for some pointers or similar layout ideas.
    Thanks in advance, and I will continue trying to come up with something myself as well.
    103 Post(s)
    7 foot width is enough for an aisle in the middle and 2 or 3 feet on each side. The question is can you make a design that allows 180 degree turns on the track? The answer to this depends on your minimum curve radius and the exact location of the doorway. If there is room for that then you have a lot of options, otherwise you may be stuck with a duck under to accomplish your goals.
    Moving coal the old way: https://youtu.be/RWJVt4r_pgc
    Moving coal the new way: https://youtu.be/sN25ncLMI8k
  3. The Following User Says Thank You to NtheBasement For This Useful Post:
    Apr 2013
    Kansas City, KS
    89 Post(s)
    Quote Originally Posted by Phill91 View Post
    Is this like a basement? Or, actually under the house? I'm a little cornfused here??? LOL
    N-joy!
    Tred - (USN-Ret.)
    Kansas City, KS
    (Sent using @ 1000Mbps)
  5. The Following User Says Thank You to Tred For This Useful Post:
    291 Post(s)
    Phil,
    Welcome and you more or less have the same room available to you as what I have to me. While you have 7' X 16' my "area" is 11' X 9'.
    This is my track plan:
    All this should show is how much track you can fit into the area you have and how you can "easily" have what you want - double mains, minimum 4 track yard and spurs.
    Now, depending on the "actual" room/area size you have to put your layout in, you could make it a "walk around layout" In other words, sit you layout in the middle of the available area. With that being said, it might be helpful if you could sketch out the exact dimensions of the room/area you have with measurements, windows, doors and an other obstacles.
  7. The Following 3 Users Say Thank You to wombat457 For This Useful Post:
    "Deep in the heart of Jersey"
    67 Post(s)
    Quote Originally Posted by Tred View Post
    Maybe @Tred there is a different meaning to "down under"
    "Tell me and I forget. Teach me and I remember. Involve me and I learn." -- Benjamin Franklin
    Mario
  9. The Following User Says Thank You to mrodtoo For This Useful Post:
    291 Post(s)
    Oh - you got that right mate!
    But as Phil comes from Rocky, (Rockhampton) chances are the house is built on stilts (for air flow and cooling) so when he says he has room "under the house" you can take that as gospel. Something like this:
  11. The Following 8 Users Say Thank You to wombat457 For This Useful Post:
    Apr 2011
    As wombat has shown, it is literally under the house.
    There are no real obstructions except for a couple of posts that hold the house up. So basically the whole area is available. I'll get a photo up asap.
  13. The Following 2 Users Say Thank You to Phill91 For This Useful Post:
  14. #8
    291 Post(s)
    Phil,
    First up mate welcome to the forums, or maybe back to them. With ALL that room you could build an epic layout jeeze, you could build an empire plus!
    Seriously though, no matter what size your layout winds up being, I'd definitely make it a free standing, walk around one. That should give you more options to play with.
  15. The Following User Says Thank You to wombat457 For This Useful Post:
  16. #9
    Apr 2011
    Having issues loading the picture from my phone, so I'll have to try the laptop tomorrow. But just picture a rectangular space with two walls meeting in a corner.
  17. The Following User Says Thank You to Phill91 For This Useful Post:
  18. #10
    Apr 2011
    So here is the aforementioned space available. Naturally, the bikes and other stuff will be moved out of the way, but as you can see... plenty of space to work with.
    I am liking the idea of a walk around style layout, changing the width to 6' which would give me plenty of room either side, and still be able to reach everything.
    Hopefully the use of flex track will give some more creative freedoms. I was hoping to run a 13/15" wide main curve to fit passenger cars easily, but can move wider to 15/16".
    Going to continue to play around with these parameters in mind and see how we go.
  19. The Following 6 Users Say Thank You to Phill91 For This Useful Post:
  20. #11
    291 Post(s)
    Phil,
    Not sure if I am understanding this properly but, if you are going to have 6' wide bench work then you could have much larger radius curves than 15" or 16". That of course will be defined by the track plan.
    If you are going to be running Passenger Cars then I might suggest you go to 18" radius curves, if possible. 15", in most cases, is workable but 18" will give you much smoother running and greater options for your train make ups. That also applies to freight trains you might want to include at some point. One lesson I learned a little while ago as well - don't pay too much attention to what manufacturers tell you the minimum radius for their engines/rolling stock is. If a manufacturer recommends 11.75" radius for a particular "car/engine" (note I said A car/engine) then add 2" to that to be sure. In some cases, what is recommended for a car is exactly that - for ONE car. Put more than one behind a train and you could have issues. Walthers is pretty good at doing that I might add.
    Flex Track is the only way to go in my opinion but, I could be bias. It will, no question, give you a great deal of flexibility when it comes to designing your plan and you wont be restricted by "pre-set" radius curves. With flex track, the only limitation (within reason) is your imagination
  21. The Following 3 Users Say Thank You to wombat457 For This Useful Post:
  22. #12
    Apr 2011
    Here is the first (pretty average and not going to stick with it) trackplan
    I must admit.. I am having trouble making something that actually looks good. Almost considering just throwing out the idea of a track plan and just winging it
    Attached Files Attached Files
  23. The Following 2 Users Say Thank You to Phill91 For This Useful Post:
  24. #13
    200 Post(s)
    I don't know what the operations guys think, but as someone who likes to run trains, I like it. Nice yard for staging or making up trains, and a nice double track main so trains can run without interference from the yard.
  25. The Following User Says Thank You to el Gato Gordo For This Useful Post:
  26. #14
    Apr 2011
    Thanks!
    I don't like the shape of it, but using flex track will be able to manipulate that away I guess. I am going to try and find a way to add a couple of industry spurs that don't interrupt the main line either. Once this has been achieved i'll probably be much happier.
  27. The Following User Says Thank You to Phill91 For This Useful Post:
  28. #15
    Jan 2009
    Florida
    It seems cool maybe and a up and under somewhere on there as you have plenty space. I’m not great with track designing but if you could make it cross over itself I think you’ll have a pretty solid track plan
    Life is Fragile. Live Everyday as if YOU Know Its Your Last.
    You Only Live Once But If You Live It Right Once Is Enough.
    20’x20’ Reggieville around the wall with peninsulas
  29. The Following User Says Thank You to allmodernkatogottohaveit For This Useful Post:
  30. #16
    291 Post(s)
    Phil,
    It is a good start but think it needs a little more "character", as said you have plenty of space to play with. Putting in an "over and under" some where would create a little more interest as well and break up the straight edges a little.
    The hardest part of any layout (I think) is deciding on the track plan. You do one, it looks good and is what you want. The next day, it just doesn't seem to be that good and you think of other ideas, things to add, delete or just change. I worked on my track plan for months and each time I looked at it, I'd change it. In then end I sat down and thought about what the layout was suppose to represent, what I wanted it to represent then designed it around that. I also think that just "whinging it" can make life a little easier, so long as you have the basic concept of what you are after and want to achieve.
  31. The Following User Says Thank You to wombat457 For This Useful Post:
  32. #17
    Apr 2011
    So needless to say, i suck at using flex on XtrkCad, however here is a general updated thought process... looks average at best, but you can hopefully see where I am going with it.
  33. The Following 6 Users Say Thank You to Phill91 For This Useful Post:
  34. #18
    DFW
    I like it! There's a lot of good train running there, and I like the yard too. There's a Book "Model Railroaders Guide to Freight Yards that's worth the price (maybe $20). It illustrates and explains all of the different realistic tracks found in many freight yards, it might give you some ideas to look into. I know I learned a lot from it... just never enough real estate for the things I want to keep adding.
    Lookin' good Flip!!
    GNR Pitch Fork Pass
  35. The Following User Says Thank You to GNMatz For This Useful Post:
  36. #19
    Apr 2011
    Sydney, Australia
    Phil, in Rocky, while a Queenslander will have airflow, humidity/moisture is going to be a factor.
  37. The Following 2 Users Say Thank You to Realwally For This Useful Post:
  38. #20
    291 Post(s)
    Looks good to me as well with plenty of scope for something of everything - nice.
  39. The Following User Says Thank You to wombat457 For This Useful Post:
  1. Opinions Needed
    By siam in forum Structures & Scenery
    Last Post: 23rd May 2016, 01:58 PM
  2. Opinions Needed
    By CaseyJones in forum Structures & Scenery
    Last Post: 30th Sep 2015, 04:49 PM
  3. Opinions needed!
    By art_mtr in forum Layout Builds, Design, & Planning.
    Last Post: 22nd Jul 2012, 06:15 PM
  4. Opinions needed for turnout control - DCC vs. non-DCC
    By Ron Plichta in forum Turnout Control Devices, Signaling, & Detection.
    Last Post: 15th Sep 2010, 11:46 AM
  5. Proposed layout : opinions and scenery suggestions wanted.
    By Fredenberg in forum Layout Builds, Design, & Planning.
    Last Post: 28th Mar 2005, 12:50 AM
