Results 1 to 15 of 15
Thread: Power supply question
    Dec 2018
    Default Power supply question
    Hi a noob here i want to buy some track and a dcc ready loco ,i have this small hobby drill from the 70's that has a power supply that has forward and reverse switch on it and also says DC track on it where the drill is attached to it ,it says 18 volts dc would i be able to use this to power the loco or do i have to buy a new power supply.here are some pics of the supplyhttps://www.flickr.com/photos/247588...posted-public/
    Mill Bay BC
    91 Post(s)
    Possibly , but remember this . Any loco you buy will be worth more than that transformer , wouldn't you want to make sure they are protected with a proper and better transformer ?
  3. The Following 3 Users Say Thank You to aflica For This Useful Post:
    181 Post(s)
    Welcome to the forum.
    If you intend to go with DCC, as you imply, I assume you're going to acquire a DCC system which should come with a suitable power supply.
    Keep the power supply you show for the drill and away from your new locomotives.
  5. The Following 3 Users Say Thank You to Paul Schmidt For This Useful Post:
    55 Post(s)
    DC locos can't handle more than 12v.
    Dec 2018
    Yes i plan to get a DCC system,i thought i could use this this power supply until i was ready to get the DCC system,seems like not a such a good idea i will wait thanks for your advice.
  8. The Following User Says Thank You to joe914 For This Useful Post:
    34 Post(s)
    Most N scale locomotives would top out around 12-14v, so if you did use that to power a locomotive I would never go above about 60%. It appears to be a DC power pack though, and for a DC locomotive it would likely work.
    That said, shorts happen. When you set down your locomotive on the track wrong the tracks may be shorted through the locomotive wheels. A DC Throttle (note I did not say power pack or power supply) includes the ability to detect this sort and remove the power. Without that function you will melt the locomotive, and I've seen it happen. Thus the question quickly becomes is melting a $100 locomotive worth re-using an unprotected power supply?
    A fairly basic, but protected throttle would be https://www.modeltrainstuff.com/mrc-railpower-1370/ which comes in around $40. Older models, like the Tech II and Tech IV can be had on ebay or swap meets for cheap where guys who've moved to 100% DCC are selling off their old throttle.
    213 Post(s)
    The 1370 is a good reliable controller. It is what I use to power my accessories and have not (as yet) had it fail in any way. I also used it to power a smaller 120' n scale I had and also never had a problem with it.
    Dec 2018
    Thanks for the link i will either get a 1370 as you suggested or one of the bachmann dc controllers off of ebay.I want to put the track in a small spare room, i only have 10 feet of length and about 24" to 26" of width,i want just a basic loop will the width be to tight to do this .
  12. The Following User Says Thank You to joe914 For This Useful Post:
    Mar 2019
    Hi...I have an hp p7-1007c desktop, with an ATX-250-12Z rev. D3R, hp part #5188-2622. it needs to be replaced. I have an hp a1483w desktop, a little older, with an ATX--300-12Z rev.CDR., hp part #5188-2625, that I'd like to use in place of the first mentioned power supply. Will the older, 300w power supply fit in the p7-1007c, and will it be ok?
  14. #10
    Mill Bay BC
    91 Post(s)
    Quote Originally Posted by FransSacco View Post
    You know this is a model railroad site ? specifically N scale model railroading . Not a computer repair site .
    The question asked by the OP was in relation to a power supply for N scale model railroading
  15. #11
    76 Post(s)
    Quote Originally Posted by aflica View Post
    NOW you tell me! No wonder I've been having so much trouble with my computer....
    https://www.nscale.net/forums/showthr...4-x-9-5-layout
  16. The Following User Says Thank You to el Gato Gordo For This Useful Post:
  17. #12
    Mill Bay BC
    91 Post(s)
    Gordon , at least it's the computer your having troubles with , and not the trains !
  18. #13
    76 Post(s)
    No, Steve, never any trouble with trains.
    Model railroading: days of consternation punctuated by periods of intense satisfaction. Or was that the other way around?
  19. #14
    Rochester, MN USA
    You can go to eBay and find MRC DC power packs that used to be fairly expensive (Tech II 2500 or 2400, for example or Tech IV's) for relatively little money. I got a Tech IV 260 for twenty dollars shipped and it's brand new. The cord is still factory wrapped. They will operate ANY DC locomotive.
    Doug
    Atlas First Generation Motive Power and Treble-O-Lectric. Click on the link:
    www.irwinsjournal.com/a1g/a1glocos/
  20. #15
    FL
    25 Post(s)
    That MRC Tech IV 260 is way more than enough for N scale.
    Mine puts out 12v at about 60% throttle.
    I’ve run 7 Atlas GP9’s at the same time with it.
  1. Missing power supply for Kato 22-014 power Pack
    By Sean Barry in forum DC Controllers
    Last Post: 10th Sep 2015, 05:41 PM
  2. NCE Power Cab Power Supply Options
    By SocalGeologist in forum DCC
    Last Post: 24th Aug 2013, 02:20 PM
  3. Help - power supply use?
    By madman in forum General Wiring
    Last Post: 3rd Apr 2013, 02:17 PM
  4. Power Cab power panel, power supply
    By dittohos in forum DCC
    Last Post: 26th Mar 2013, 02:32 AM
  5. DC power supply
    By porkypine52 in forum DC Controllers
    Last Post: 18th Apr 2006, 03:31 PM
