Results 1 to 11 of 11
Thread: Mixing DC on DCC
    Ontario, Canada
    14 Post(s)
    Default Mixing DC on DCC
    I am wired up for DCC, using MRC control.
    I know MRC doesnít allow me to run DC as other systems do, so looking for plan b as I have a couple DC locomotives that arenít worth/able to be upgraded.
    If I install a switch to flip between DCC and DC - should I just take my DCC locomotives off, or wire up a special DCC only parking spot(s).
    Or what other options am I missing?
    46 Post(s)
    Won't your digital loks run on DC? So far as I know, most decoders have a CV whose default setting allows running on DC as well as DCC; one needs to change the CV setting if one wants to disable that ability.
    Fort Smith, Arkansas
    The DCC units will be fine, it's the DC units you don't want getting AC power.
    Daniel Dawson
    Ontario, Canada
    14 Post(s)
    So I should aim to hide the DC units or remove them when switching over?
    31 Post(s)
    Do you have block control for running DC? Otherwise all the locos will move at once. Personally when I switch over (which isn't often) I box up the incompatible ones so there is no mistake.
    Correct. Also I usually turn the DC options off on my DCC units. As someone else said, I try to do my best to not have mixed units on the layout at the same time at all, just because I'm cautious, but in theory you should be fine as long as the DC units don't get digital power.
    Daniel Dawson
    46 Post(s)
    Just curious, Daniel, but does it serve any useful purpose to disable the DC capability on your decoder equipped loks?
    Yes, it prevents run aways when there is a blip in the DCC system. The decoder incorrectly senses DC, switches to DC mode and goes full speed.
    Many clubs that run DCC have a rule that DC capability be turn off on all locos.
  9. The Following 3 Users Say Thank You to kingmeow For This Useful Post:
    Quote Originally Posted by kingmeow View Post
    Yep. Pretty much this. And the fact that they don't seem to run on DC that well anyway.
    Daniel Dawson
  11. #10
    46 Post(s)
    Thanks! I have never heard of that happening, nor have I ever experienced it in 6 years with DCC. But I don't doubt your info - just lucky, I guess. And since I am a club of "one" I can make my own rules.
  12. #11
    Tulsa Oklahoma USA
    I have an ABA set of E8/9s that have not been converted to DCC yet that I run on occasion on my Zepher powered layout. Out of a dozen DCC locomotives that sit on the layout, one engine seems to be sensitive to running the E8/9s and always tries to start up and run away. Took me a minuet to figure out what was going on.
  1. Mixing rail joiners
    By TimW in forum Trackage
    Last Post: 27th Jan 2015, 11:59 PM
  2. mixing different brands of track
    By NSnosteam in forum Layouts, Design, & Planning.
    Last Post: 20th Jan 2014, 05:48 PM
  3. Mixing Track Help
    By Chicago Rail in forum Trackage
    Last Post: 28th Feb 2013, 07:21 AM
  4. Mixing brands? (was: HELP?)
    By train in forum Rollingstock
    Last Post: 15th Jul 2011, 09:21 PM
  5. Mixing Manufacturers
    By Agatheron in forum DCC
    Last Post: 7th Mar 2007, 04:38 PM
