Results 1 to 3 of 3
Thread: Replacement motor for Atlas H16-44
    May 2011
    Ontario
    Default Replacement motor for Atlas H16-44
    Hi all,
    I'm looking for a replacement motor/flywheel assembly for an Atlas H16-44 loco. The current one - well, it had a run-in with a soldering iron. Didn't go well.
    I checked the Atlas website but they have none listed in stock. Is this part custom to the H16-44, or is there a motor from another loco that would work as a stand-in?
    Many thanks,
    Patrick
    Apr 2019
    If you just need the plastic brush housing any atlas should work you just need to tap the rear flywheel off. Also I've seen these motors on eBay that atlas uses for dirt cheap here's 2 for $2.50 shipped.
    to get the flywheel off take your Dremel wheel straight into a piece of steel about 1/8" thick and use a 1.5mm screwdriver and hammer to tap the motor shaft until it falls out the flywheel.
    https://www.ebay.com/itm/2PCS-DC-12V...wAAOSwUKhbkiHK
    Perth. Western Australia
    Cheers,
    Russ
    CEO of Devil's Gate Mining Co.
  1. Replacement motor brushes?
    By Spookshow in forum Diesel
    Last Post: 22nd Mar 2017, 07:14 AM
  2. rivarossi replacement motor
    By Bassbone8vb in forum General Rail Discussion
    Last Post: 4th Mar 2017, 10:56 PM
  3. Replies: 5
    Last Post: 24th Mar 2012, 02:53 PM
  4. SD7 motor replacement
    By ozzie Bill. in forum Diesel
    Last Post: 2nd Oct 2011, 06:56 PM
  5. Replacement motor for LL SD7
    By GNFA310 in forum Diesel
    Last Post: 15th May 2006, 12:32 PM
