Thread: Kato RS-2 how to get trucks off and disassemble them
    Mar 2014
    Riverview NB
    Default Kato RS-2 how to get trucks off and disassemble them
    I was going to clean and lube my Kato RS-2, but I find the trucks hard to remove. I'm afraid to really yank them, in case I break something. And I tried to take the trucks apart, and same thing, they are hard to disassemble. On the trucks there are four tabs. Do I have to press down on all four tabs to get the truck apart?
    Any suggestions would be appreciated.
    Fort Smith, Arkansas
    23 Post(s)
    Quote Originally Posted by Chaos Railway View Post
    Is this the Kato/Atlas made variant? Those can be quite a chore.
    Daniel Dawson
    Twin Cities, Minnesota
    164 Post(s)
    Yanking on Kato trucks is rarely a good idea as it's possible to damage the clips on the truck collars that hold the truck inside the chassis. I would recommend removing the shell and then loosening up the two chassis screws first.
    The truck sideframes and bottomplate are all one piece that clips to the bottom of the main truck assembly. I generally just bend the sideframes outward from the top to free up the clips.
    -Mark
  4. The Following 3 Users Say Thank You to Spookshow For This Useful Post:
    Mar 2014
    Riverview NB
    Daniel,
    I'm not sure which model I have. The trucks have two axles each, and the instruction sheet is labelled "Alco RS-2 RSC-2".
    Milne
    Mar 2014
    Riverview NB
    Thanks Mark. Will have to give this a try.
    Milne
    Bozeman,MT
    RS2 is 4 axles,RSC2 is 6 axles...…..the chassis are identical and you can put either set of trucks on the chassis or 1 of each if you want. As Mark said, remove the shell and loosen the screws to remove the trucks...…..they are a bit sturdier than some Kato trucks mounts, but better safe than sorry. And yes, you need to unsnap those 4 little clips to get the truck apart......sometimes the flex method works, sometimes I've had to resort to sliding a thin screwdriver in and prying. I've also used a toothpick to push each tab out one at a time...…..start with the least abusive method and work up till they come apart.
  8. The Following User Says Thank You to MRLdave For This Useful Post:
    Mar 2014
    Riverview NB
    Thanks Mark. I took your advice and loosened the chassis screws. It worked.
    Quote Originally Posted by Spookshow View Post
    https://www.nscale.net/forums/cache....ators2mech.JPG
    -Mark
  10. The Following User Says Thank You to Chaos Railway For This Useful Post:
  1. Disassemble Atlas Diesel Frame
    By dwwojcik in forum Diesel
    Last Post: 4th Jun 2016, 10:24 AM
  2. How does one open, disassemble Lima combined car?
    By trainstrainstrains in forum Modeling Techniques
    Last Post: 17th May 2016, 12:37 AM
  3. kato tender trucks
    By bmwfitness28 in forum Steam
    Last Post: 13th Jul 2013, 10:31 AM
  4. Kato C30-7 Trucks
    By Blade3562 in forum Diesel
    Last Post: 17th Apr 2012, 01:51 PM
  5. Kato C44-9W Trucks Broken
    By fifer in forum Diesel
    Last Post: 2nd Dec 2006, 08:43 PM
