Results 1 to 8 of 8
Thread: reinstalling bachmann doodlebug front truck
    Feb 2015
    Alberta, Canada
    Default reinstalling bachmann doodlebug front truck
    So long story short does anyone know how to put the front powered truck back in?
    Problem I'm having is the little swivel knuckle u-joint thing on the truck has a square hole that of course mates with the square shaft off the motor. But how do you line them up?
    I'm thinking the decoder has to be unscrewed from the frame?
    Any advice would be greatly appreciated.
    Keith
    The Northern Alberta Railways, once the 3rd largest railway in Canada.
    Twin Cities, Minnesota
    188 Post(s)
    Yeah, you have to get that decoder board out of the way. Too hard to finagle the driveshaft otherwise.
    -Mark
  3. The Following User Says Thank You to Spookshow For This Useful Post:
    Feb 2015
    Alberta, Canada
    Thanks Mark
    Keith
    Mar 2016
    Whilst on the subject of the front truck. How much 'front-to-back' (not swivel, for cornering) should there be? I've an issue with my doodlebug not running 'smoothly' - it seems to 'chatter' as if it is rocking back and forth. It seems to run better in reverse than forward, but still has an issue.
    All ideas welcome.
    Almost Heaven
    212 Post(s)
    Quote Originally Posted by MDB View Post
    All ideas welcome.
    Hmmm, that could be a symptom of a broken gear, a seemingly chronic problem for Bachmann. Check the gears for a split or a missing tooth.
    Split gears -- might as well be Bachmann's corporate logo.
  7. The Following User Says Thank You to Paul Schmidt For This Useful Post:
    MDB
    Mar 2016
    Thanks for the suggestion Paul.
    I removed the front truck and examined the gears while slowly turning the drive shaft. I couldn't see any damage. I wasn't keen on opening up the mechanism (those are some very fine screws!) so I decided to reassemble the put it back together and see how it ran. Back on the track - I had NO response at all! Aaaaagh!!! (plus a few more choice descriptive words). After failing to successfully reset the decoder I realized one of the power wires had come off. I was tricked into thinking power wasn't an issue as the 'passenger area' light was on. Once the wire was soldered the test run could begin.
    I'm not sure what I did, but I'm happy to report the Doodlebug services have recommenced!
    I had previously removed the motor, but not the front truck. Maybe it just needed to be 're-seated' slightly further into the frame? Whilst I'd like to know what 'fixed' my issue, I'm still happy it is back in service.
  9. The Following User Says Thank You to MDB For This Useful Post:
    Almost Heaven
    212 Post(s)
    Nice to it's back in service and no faulty gear!
    Mar 2007
    49 Post(s)
    It's such a crapshoot with these. I had a first-run PRR and test ran it, put it in the display case. Had it out to run a couple times, never really happy with it because it was so disturbingly noisy and was stalling as well; decided to put a Tomytec drive in it.
    Good thing I did because while I was salvaging things like the truck sideframes the wheels literally fell off because the plastic gear centers had cracked. Terminal on what was really a brand-new drive.
    But the good news is that you can really do well with a Tomytec drive in these if they do go south on you, and you'll get 8x8 drive and pickup out of it as well.
    Randgust N scale kits web page at www.randgust.com
  12. The Following 3 Users Say Thank You to randgust For This Useful Post:
  1. Bachmann Doodlebug
    By MRLdave in forum DCC
    Last Post: 20th Jan 2018, 12:59 AM
  2. Anyone have a Bachmann Doodlebug?
    By wingedone in forum Motive Power
    Last Post: 7th Mar 2017, 02:43 PM
  3. Bachmann Doodlebug Paint Shop
    By P-LineSoo in forum Motive Power
    Last Post: 17th Oct 2016, 05:45 PM
  4. Life-Like E8 SF front truck problem
    By bshire284 in forum Diesel
    Last Post: 26th Mar 2015, 07:19 PM
  5. Any Bachmann Doodlebug Operators?
    By Sherman in forum Diesel
    Last Post: 22nd Nov 2010, 05:10 PM
