Results 1 to 10 of 10
Thread: Esu Loksound Select Micro, onboard LEDs as front/rear headlights?
    Apr 2017
    Southern California
    Lightbulb Esu Loksound Select Micro, onboard LEDs as front/rear headlights?
    Hello all,
    I have a pair of V5 Loksound Select Direct Micros for use in my Atlas GP38-2s and I am at a loss on how to configure the onboard SMD LEDs to be front/rear headlights. I read that they are Aux 1/2 and when I enable F6 (iirc) they are both on.
    I have never had a ESU decoder and the function configuration in Decoder Pro is a bit confusing. I also did a bit of searching but I was not able to find anything. I plan to sit down and dig into how to use the function maps but sadly I have limited time for modeling over the next few weeks.
    Loksound Select Direct Micro folks, how can I configure the decoder to use the SMD LEDs as front and rear headlights?
    Preferably with Decoder Pro.Thanks!
    ** updated because I use the Direct Micro one
    Will
    -- SocalUP
    Those are configured to be the front and rear ditch lights. Why don't you solder the included LEDs to the pads for the front and rear lights?
  3. The Following User Says Thank You to gatrhumpy For This Useful Post:
    Apr 2017
    Southern California
    Sadly they wont fit with capacitors in the light box and a speaker box on the rear (already tried).
    I'm doing a build based off this thread:
    https://www.therailwire.net/forum/in...?topic=44479.0
    Someone asked how to program the lights but there was no response.
    I could use wired 402s but would prefer the onboard ones.
    Thanks!
    Will
    -- SocalUP
    The LEDs are too dark to effectively be used as headlights.
    Apr 2017
    Southern California
    They're plenty bright for front/rear lights in a GP38-2.
    Will
    -- SocalUP
    Oklahoma, USA
    Quote Originally Posted by socalup View Post
    Depends on frame mods, I guess. I've installed a 73100 in a GP38-2 and, whilst the rear onboard is acceptable, adding in an SMD for the front lights is now on my to-do list. As for configuring the LEDs... I don't know how helpful the following two images will be but it's how my GP38 is set up. The images are from LokProgrammer but the JMRI screens should be roughly similar.
    Sam
    Apr 2017
    Southern California
    Thanks @samusi01 that got it for me.
    I've attached my JMRI for future reference. I swear I tried this but I guess not
    Now to fix my ditch lights
    Will
    -- SocalUP
    Oklahoma, USA
    Sounds like you’ve got some soldering in your future! The tiny pads on the 73100 always make me a bit nervous.
    Apr 2017
    Southern California
    I'm not a fan at how close they are to other bits attached to the board.
    I managed to get my lights installed, with a resistor, and for some reason when its 'off' they still have a bit of power and are very dim, 'on' they're plenty bright.
    Any idea what that could be? I do have the v5s and really hope its not some sort of board issue.
    Will
    -- SocalUP
  11. #10
    Oklahoma, USA
    Haven't the foggiest, unfortuantely. I've not yet worked with any v5s and almost all of my LokSound are 73100/73199 (I've only three that aren't that form factor). I don't recall if any of them display this 'never-off' feature or not. The only troubleshooting thing I can think of is perhaps there is a setting that is allowing them to remain illuminated. Have you set them to be dimmable and if so, does that feature work? Next step might be the folks at TRW, the Yahoo ESU group, or ESU itself.
    Sam
  1. Loksound Select Micro w/Ditchlights
    By GM50 4164 in forum DCC
    Last Post: 30th Jan 2018, 04:42 PM
  2. LOKsound Select Micro decoder install!
    By AKCentral in forum Diesel
    Last Post: 11th Jan 2017, 08:25 PM
  3. Replies: 4
    Last Post: 19th Jul 2016, 04:59 AM
  4. Replies: 15
    Last Post: 4th Feb 2015, 09:22 AM
  5. ESU LokSound Select Micro issue
    By craigbtrains in forum DCC
    Last Post: 16th Oct 2012, 05:13 PM
