Results 1 to 6 of 6
Thread: Small Screw
    Jan 2015
    west point, ca, usa
    Default Small Screw
    I am looking for some of these screws or maybe just the correct name?? Slotted shoulder screw??
    ... I call that a 'part.'
    it is a shoulder type screw.
    I do not think they are a standard and easy to find item.
    If I need to replace one, I usually use a screw inside a brass tube.
    mostly they are steel and brass will not hold in service.
    yer best bet is to talk to the outfit what made it...
    victor
    Jan 2015
    west point, ca, usa
    I'm not sure if they make the car anymore. Someone else mention tubing over screw as well. Still need to find screw!
    May 2005
    Southern Colorado
    56 Post(s)
    "Do Not Hump!?!?! Does that mean what I think it means?!?"--Michelle Blanchard
    "People saw wood and say nothing, but railroad men saw trains and say things that are better left unprinted."--Charles De Lano Hine
    Down with UP
  5. The Following User Says Thank You to ranulf For This Useful Post:
    nice web site.
    that has the look of 'made to order' and I would not mind being shown I miss-read.
    sd75i,
    if you get screws from Precision shoulder screws, please let us know how it went?
    maybe they will send out samples... call for that.
    your problem is that you don't know what screw fits the ...
    umm... cleaning pad?
    first, assume it is metric because most n-scale is.
    and 1.5mX1 is common and is close to 0-80.
    what I can't help you with is where you might find a test screw. got a minitrix k4?
    I think the shell screw is this size( oh that is an old memory...)
    the m-trix 0-6-0 is the same size and far shorter.
    most of the old Atlas/RR steam used M2x1 If my increasingly feeble memory serves.
    this size is close to 1-72
    m1.4 and m1.8 exist so you may find the hunt goes a while.
    victor
    Jan 2015
    west point, ca, usa
    This is what I'm choosing to go with right now! Bigger but same type concept of screw. Gonna make my own track cleaning cars. There is a easier way with nails and masonite but I want to see if I can make a couple the way roco did or (does).
  1. NCE PowerCab controller screw?
    By edfhinton in forum DCC
    Last Post: 29th Jul 2016, 12:46 PM
  2. What screw to mount trucks?
    By trainboyh16-44 in forum Rollingstock
    Last Post: 20th Dec 2011, 06:29 PM
  3. Small screw driver
    By woodone in forum Tooling
    Last Post: 26th Apr 2011, 08:20 PM
  4. Bachman coupler screw size?????
    By 632bbc in forum Diesel
    Last Post: 21st Mar 2010, 03:11 PM
  5. I've got a screw loose....
    By Bryan in forum Steam
    Last Post: 12th Oct 2004, 07:44 PM
