Results 1 to 12 of 12
Thread: Motion sensor for activating lights in passenger cars
    Jun 2019
    Lightbulb Motion sensor for activating lights in passenger cars
    I'm thinkin of installing lighting in my passenger cars, led strips etc.
    Ideally, I think of a system that switches the lights automatically when the car is in motion. Using some kind of vibration sensor that triggers the lighting for some minutes (so cars keep lit in short station stops), and when the car stops longer time, lights switch off.
    Does anyone have experience in building this? What kind of sensor or circuit can be used?
  2. The Following User Says Thank You to jozasa For This Useful Post:
    Oct 2014
    Northwest Arkansas, USA
    Have not built one but I'd probably try something like this: https://www.adafruit.com/product/1766 coupled with a 555 timer circuit wired to generate a single long pulse when triggered.
    -or-
    If you're taking power through the wheels, you could also use a voltage comparator to sense the voltage level. The output would go high when a certain voltage was reached and stay high until the voltage fell below a certain point. The output would enable a pulse generator (555 timer) to light the bulbs/LEDs.
    GDR
  4. The Following User Says Thank You to Gary Rowan For This Useful Post:
    Sequim WA
    147 Post(s)
    Quote Originally Posted by Gary Rowan View Post
    That would work for DC on the rails. For DCC the sensor switch would seem a better solution. Depends on how sensitive it is; would "slinky effect" couplers cause the lights to go on-off, on-off or could the 555 circuitry compensate for that? Might require a keep-alive cap at the threshold. ...Just musing.
    Paul Schmidt
    Shasta (2008-2020) -- All good dogs should live forever
    Southern Railway's Slate Fork Branch
    Check out Appalachian Railroad Modeling!
  6. The Following User Says Thank You to Paul Schmidt For This Useful Post:
    Oct 2014
    I believe that once triggered, the 555 would stay on for the duration of the timing interval, eliminating any 'bounce' from the sensor.
    Here's a couple of links for reference:
    http://www.circuitbasics.com/555-tim...nostable-mode/
    https://circuitdigest.com/electronic...ircuit-diagram
  8. The Following User Says Thank You to Gary Rowan For This Useful Post:
  9. #5
    Jun 2015
    SW London
    In the UK Train Tech do such things, including sound modules:
    http://www.train-tech.com/index.php/...coach-lighting.
    They are a bit big for N though.
    Simon
  10. The Following User Says Thank You to Simon D. For This Useful Post:
  11. #6
    Sequim WA
    147 Post(s)
    Yeah, that would do it. Would require some fussy work to fit into an N scale passenger car. But the parts are cheap.
    So, @Gary Rowan, are you thinking that the fast sensor switch would be wired one side to ground and the other to the trigger of the 555? Then a large-value tantalum cap for C1 and large value for R1 to keep the threshold below two-thirds VCC for a long duration? That's what I'd try first.
    Paul Schmidt
    Oct 2014
    @Paul Schmidt,
    I would build the circuit as shown in the circuitbasics.com link, substituting the sensor for the push-button switch. My preference would be to use an electrolytic cap instead of a tantalum. That sort of depends on whether or not you can get a large enough tantalum for the desired timing duration according to the formula in the link.
    It's not to hard to fit into an N scale car. Years ago, I built a 555 flasher circuit for a FRED that fit nicely in an N scale caboose.
  13. The Following User Says Thank You to Gary Rowan For This Useful Post:
  14. #8
    Sequim WA
    147 Post(s)
    No kidding! But sure, it could be done, 555s being so small. Did you power it from the track?
    Paul Schmidt
    Oct 2014
    If I recall correctly, I used some axles and pickups from a dead steam loco tender and swapped them into the caboose.
  16. The Following User Says Thank You to Gary Rowan For This Useful Post:
    Mar 2012
    Buhl, Idaho
    I would use a decoder and tell it to turn on with the loco that was pulling them.
    ___________Just do it in Vinyl!__________
  18. The Following User Says Thank You to Comfortably numb For This Useful Post:
  19. #11
    Sequim WA
    147 Post(s)
    Quote Originally Posted by Comfortably numb View Post
    But that would take all the fun out of cramming something we made ourselves into a passenger car body!
    Paul Schmidt
  20. #12
    Mar 2012
    Buhl, Idaho
    You still have to build it and then program it , so it close.
  21. The Following User Says Thank You to Comfortably numb For This Useful Post:
  1. Replies: 5
    Last Post: 1st Jun 2014, 09:14 PM
  2. Replies: 12
    Last Post: 20th Mar 2014, 02:46 PM
  3. Replies: 3
    Last Post: 20th Jul 2013, 07:16 PM
  4. Replies: 5
    Last Post: 11th Apr 2013, 08:18 AM
  5. Lights in Passenger Cars
    By Atouk in forum General Wiring
    Last Post: 23rd Dec 2004, 06:29 PM
