Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 130
Thread: Scratch built Trestle question...
    266 Post(s)
    Default Scratch built Trestle question...
    In a nutshell, what size/dimension "Bass Wood" should be used or recommended to build a Trestle Bridge?
    Nov 2019
    Brunswick, Ohio
    Hi Tony,
    A lot of the guys in our club use bamboo skewers for the pilings.
    1/32 x 3/32 for the 4"x12" wood bracing.
    If you haven't done so, consider building a jig to keep the parts in alignment during gluing.
    Happy Modeling
    Bruce
  3. The Following 3 Users Say Thank You to BruceNscale For This Useful Post:
    266 Post(s)
    Thanks Bruce, using bamboo skewers is a good idea. I was thinking about square pylons but round could also work In the event I do go with square pylons, I am guessing that 3/32 Bass Wood would work.
    A fair while back I bought a Trestle Kit that came with a Jig for N Scale Trestles - I still have that around here somewhere. If not, having a jig is a necessity and will make one.
    Zombie Hill, Vermont
    135 Post(s)
    Long time ago I built a trestle and made my own jig for it, but it’s probably long gone. I will be building a trestle for my micro layout so look forward to your progress as well.
    ~ Charles
    :shay:
  6. The Following User Says Thank You to zosimas For This Useful Post:
    May 2005
    Southern Colorado
    59 Post(s)
    3/32 square should do fine for the upright parts too if you'd rather square. That's 15 inches in N.
    Easy rule of thumb for estimating stuff like that is to remember 1/16" is 10 inches in N scale.
    "Do Not Hump!?!?! Does that mean what I think it means?!?"--Michelle Blanchard
    "People saw wood and say nothing, but railroad men saw trains and say things that are better left unprinted."--Charles De Lano Hine
    Down with UP
  8. The Following 5 Users Say Thank You to ranulf For This Useful Post:
    Perth. Western Australia
    53 Post(s)
    Quote Originally Posted by ranulf View Post
    And to take it a bit further...
    1/16 = 1.5mm = 10 inches in N scale
    Cheers,
    Russ
    CEO of Devil's Gate Mining Co.
  10. The Following User Says Thank You to mosslake For This Useful Post:
    64 Post(s)
    @wombat457, not sure what decade you are modelling or how high the trestle is. Per my Mallory's, a 25' 1908 NYNH&H single track timber bent has these members:
    Piles: 10"
    Lower horizontal and cross braces: 2-3"x10"
    Top horizontal under the stringers and on top of the piles: 12"x16"x14'
    For a taller 100' 1890 trestle he shows 12x12 (outer) and 10x12 batters (uprights), 6x12 longitudinals and 3x12 longitudinal cross bracing.
    Stringers depend on span from bent to bent and get tripled under each rail:
    11' - 3"x12"
    13' - 3"x14"
    17' - 3"x16"
    23' - 4"x16"
    Good book - "Bridge and Trestle Handbook" by Paul Mallery.
  12. The Following 3 Users Say Thank You to NtheBasement For This Useful Post:
    266 Post(s)
    Hmm, well the Bass Wood I ordered arrived and it was the wrong size - 3/16th X 3/16th. I think 30" pylons might be a tad over kill. Not sure if I made the mistake or the wrong stuff was shipped, either way it doesn't matter, I'll find a use for it
    Any how, the correct size has been ordered 3/32nd X 3/32nd and should be here by the end of the week early next week along with the rest of the wood.
  14. #9
    266 Post(s)
    How do these measurements look to you guys:
    My intention is to have a walkway down one side of the track.
    135 Post(s)
    Do you have a scale ruler? I highly recommend one if you don’t. Beyond that I have no idea
    ~ Charles
    :shay:
  16. The Following User Says Thank You to zosimas For This Useful Post:
  17. #11
    266 Post(s)
    Charles,
    No I don't and your right, that is something that should be gotten.
  18. #12
    49 Post(s)
    There is a Resource Page for Grandt Line here with Trestle Plans
    https://www.grandtline.com/tips-tech...ource-gallery/
    As well as CPR plans
    Attached Files Attached Files
  19. The Following 4 Users Say Thank You to Scotian_Huntress For This Useful Post:
  20. #13
    266 Post(s)
    One other thing - suggestions to simulate Bolts for the trestle? Are there any Nuts and Bolts in N Scale that might work?
  21. #14
    49 Post(s)
    Quote Originally Posted by wombat457 View Post
    Not really - they are too small but you can simulate them as described at this website
    https://jamestrainparts.com/2015/08/...cale-trestles/
  22. The Following User Says Thank You to Scotian_Huntress For This Useful Post:
  23. #15
    266 Post(s)
    Thanks Scotian and yeah a quick search for micro nuts and bolts didn't turn anything up
  24. #16
    Sep 2013
    Fulton, NY
    42 Post(s)
    Archer Transfers makes 3D decals that work well for small details like bolts and rivets. I've used their louvers on loco builds, they works great.
    https://www.archertransfers.com/Surf...ilsNscale.html
    Edit- I guess they don't make bolts... My memory misremembered again. :P
    Andrew
  25. The Following 2 Users Say Thank You to conrailandrew For This Useful Post:
  26. #17
    Jul 2010
    Westminster, Ca. USA
    35 Post(s)
    My recommendation - use styrene. I have built trestles out of scale lumber -- they are OK. Styrene is much stronger. -- and, in my opinion, easier to work with.
    As for nut & bolt detail -- I don't feel they are needed -- not in our scale.
    Here is what I did: It is about 2 feet long
    Here is a close up:
    Thanks,
    Wolf
  27. The Following 12 Users Say Thank You to SP-Wolf For This Useful Post:
  28. #18
    135 Post(s)
    @SP-Wolf what part number styrene did you use?
    ~ Charles
    :shay:
  29. The Following User Says Thank You to zosimas For This Useful Post:
  30. #19
    266 Post(s)
    Wolf, I agree that styrene would be stronger and your bridge looks absolutely amazing; however, I find working with wood easier and it gives a natural looking wood finish when stained If I were building any other type of bridge though, styrene would be my first choice I think.
    As for the nuts and bolts idea - your right, in hindsight, our scale is a bit small to include that finer detail.
  31. #20
    Jul 2010
    35 Post(s)
    Quote Originally Posted by zosimas View Post
    Hi Charles,
    When I get home this evening -- I will try and figure that out for you. (It's been a couple of years).
    If I remember correctly -- I used 3 different sizes.
    Wolf
  32. The Following 2 Users Say Thank You to SP-Wolf For This Useful Post:
  1. Scratch built log car
    By genshed62 in forum Rollingstock
    Last Post: 19th Oct 2014, 04:39 PM
  2. Scratch built house
    By Taylure (RIP) in forum Scratchbuilding & Kit Bashing
    Last Post: 29th Feb 2012, 02:19 AM
  3. scratch-built cars
    By Sora Rail in forum Rollingstock
    Last Post: 18th May 2011, 07:06 AM
  4. Scratch Built Tool & Die co.
    Last Post: 14th May 2011, 09:51 AM
  5. Scratch or kit bash my way to Bellevue Trestle
    By dugbonz in forum Scratchbuilding & Kit Bashing
    Last Post: 5th Feb 2009, 12:04 AM
