Thread: Loksound 50326 speaker
    Perth. Western Australia
    34 Post(s)
    Default Loksound 50326 speaker
    I have 3 Loksound 50326 speakers to use with Tsunami2 sound decoders. Has anyone used these speakers and how did you install them?
    https://www.traintekllc.com/esu-5032...8-ohm-speaker/
    Cheers,
    Russ
    CEO of Devil's Gate Mining Co.
    45 Post(s)
    There are some youtube videos on installation that may be helpful
  3. The Following 2 Users Say Thank You to Scotian_Huntress For This Useful Post:
    34 Post(s)
    Quote Originally Posted by Scotian_Huntress View Post
    @Scotian_Huntress, Thanks, I didn't think of U-tube!!
    Cheers,
    Russ
    Palo Alto, CA
    I believe that if you are installing more than one speaker per each decoder, just make sure to keep the resistance above the decoder’s recommended output. For example, if the decoder specifies 8 ohms or greater, if you wire two 8 ohm speakers in series, you’ll be at 16 ohms, which should be fine; but if they’re wired in parallel, you wind up with 4 ohms and could damage the decoder. See: http://www.sbs4dcc.com/tutorialstips...ispeakers.html.
    Those of you with more engineering experience (not the locomotive kind) please confirm that I am correct.
    Good luck!
    34 Post(s)
    I'll be doing well just to fit 1 decoder and speaker in the tender, considering the motor is in there as well.
    But thanks for the advice @danb
    Cheers,
    Russ
  1. Speaker installs ???
    By wombat457 in forum Steam
    Last Post: 21st Jul 2018, 07:21 PM
  2. Speaker Baffle - Which Way?
    By IndyNScale in forum DCC
    Last Post: 10th Jun 2017, 12:06 PM
  3. 16 MM Round Speaker
    By Chicago Rail in forum DCC
    Last Post: 19th Feb 2017, 06:29 PM
  4. Speaker size?
    By TwinDad in forum DCC
    Last Post: 2nd Aug 2014, 11:12 AM
  5. New Speaker Enclosures
    By DCUTTTING in forum Product & Service Announcements
    Last Post: 12th Mar 2014, 07:30 PM
