Results 1 to 19 of 19
Thread: Ballast and Static Electricity - *SOLVED*
    Apr 2019
    Default Ballast and Static Electricity - *SOLVED*
    All eager to ballast your track, you get that bottle out, pour some into a folded index card to use as an applicator and you get a small amount on the track. You push, prod, brush and sweep, but it mostly just clumps up, sticking to your brush, on top of the ties and on the side of the rails. No amount of careful brushing helps- in fact it gets worse!
    DRAT!
    CURSE YOU STATIC CLING!
    It's just as annoying as your socks sticking to your shirts in the dryer, but at least there you have antistatic dryer sheets to fix that.
    Wait a minute... (goes off to snag a dryer sheet from the laundry room)
    Let's just wipe the track down and apply some ballast.
    AHAH!
    Now the ballast lays down smoothly, a brush does its job as intended. Excellent.
    And now my ballast smells like fresh laundry!
    Jun 2020
    Quote Originally Posted by Vegaman Dan View Post
    https://www.nscale.net/forums/attach...7&d=1614664889
    DRAT!
    https://www.nscale.net/forums/attach...8&d=1614664889
    AHAH!
    That is something not many would have thought of. You have done a good job with the final project.
  3. The Following User Says Thank You to VRB60 For This Useful Post:
    289 Post(s)
    Interesting but at the end of the day, the "quality of the ballasting work" comes down to the amount of care and time taken to spread the ballast. Going by the last picture above, there was more time taken spreading the ballast between the rails than was taken spreading it along the outside of the rails. Either that or "dryer sheets" don't work all that well for the outside of the rails.
    Apr 2019
    Attempts to shape the ballast resulted in particles clinging to the rails, brush, etc. No amount of effort, careful or not, reduced this behavior.
    Mind you, this was Woodland Scenics, which is not real rock like some suppliers so likely not reacting the same way.
  6. The Following User Says Thank You to Vegaman Dan For This Useful Post:
    52 Post(s)
    I've never had this problem. Could the static cling issue be due to an environmental factor in your layout room? Perhaps it has very low humidity and/or static-prone carpeting?
  8. The Following User Says Thank You to MetroRedLn For This Useful Post:
    289 Post(s)
    @MetroRedLn
    Static is caused by two (or more materials) having opposing ion compositions. Materials with negatively charged ions will repel materials with negatively charged ions. Materials with positively charged ions will repel materials with positively charged ions. Nickel/Silver (track Rails), plastic (Track Ties) and ground foam (Ballast) all produce negatively charged ions; therefore, they will repel one another not attract one another in the same way the negative pole of a magnet will repel another negative magnet pole. As such, static electricity where rails, ties and ballast is concerned here, is not the reason for why ballast ends up where it ends up.
    As you mentioned Metro, you along with a great many others here (myself included) have never had a problem laying ballast and getting it where it is suppose to go.
    As a foot note, apparently hair and fur are made up of positive ions and could explain why the OP has an issue with ballast sticking to his brush, if he uses a natural bristle brush. If that is the case, use a nylon or synthetic bristle brush instead and that will resolve the ballast sticking to it issue; although, some ballast (especially the foam variety) will tend to stick to a brush especially if the brush isn't a stiff type.
  10. The Following 4 Users Say Thank You to wombat457 For This Useful Post:
    255 Post(s)
    If you use real crushed rock or sand and not crushed walnut shells, static electricity is not an issue.
  12. The Following 2 Users Say Thank You to The Ol' Curmudgeon For This Useful Post:
    Apr 2019
    The effect happens if natural or synthetic brushes are used, finger tips, wood sticks, etc. I used metal tools as well.
    Real stone ballast does not have this issue, but I am not using that so not really relevant.
    Short answer is that the dryer sheet works. It also works well to wipe your tools and clothes with if you are working with shaping foam scenery bases for the same issues.
  14. The Following 5 Users Say Thank You to Vegaman Dan For This Useful Post:
    NJ, near old Lehigh Valley RR
    60 Post(s)
    The good news is that you probably won't need a static grass applicator to do grasses!
    Great solution to sticky issue!
    Steve - Jugtown Modeler..............Don't know enough about railroading yet, but scale modeling is my life..............Web-Folio
    The introduction of so powerful an agent as steam to a carriage on wheels will make a great change in the situation of man. -- Thomas Jefferson, 1802
  16. The Following 6 Users Say Thank You to Jugtown Modeler For This Useful Post:
    Netherlands
    227 Post(s)
    Thanks hadn't tried this yet. I had the same problem , WS ballast and foam base ( that is blue foam isn't it ?) , I solved it by painting the foam with an acrylic paint before ballasting, works well for the outside of the rails . Have got to try your method for the inside of the track.
    As long as I can model in N-scale, I know I'm not old
    My Flickr Pages
    http://www.janbouli.com
  18. #11
    255 Post(s)
    And what residue, if any, is swiping the rail with a dryer sheet leaving behind? Or, in other words, is the Law of Unintended Consequences waiting to pounce.
    Well, let's look at them. Dryer sheets contain many ingredients, but the most common are:
    1) dipalmethyl hydroxyethylammoinum methosulfate, a softening and antistatic agent. The jury seems to be out on the toxicity of this compound.
    2) fatty acid, a softening agent.
    3) polyester substrate, a carrier.
    4) clay, a rheology modifier, which helps control the viscosity of the coating as it begins to melt in the dryer.
    Now, Vegaman Dan, you can wipe whatever you choose on your layout. Makes no nevermind to me. But I'm filing this idea under "Nothing Good Can Come From This."
    Maybe going over the rails with a piece of relatively benign aluminum foil would work as well, as balled up aluminum foil is often used in lieu of dryer sheets as an anti-static material.
  19. The Following 6 Users Say Thank You to The Ol' Curmudgeon For This Useful Post:
  20. #12
    46 Post(s)
    From the electronics world ... treat it as a grounding issue.
    Turn off the power to tracks.
    Buy a grounding wrist strap from Ebay.
    Ground yourself to the track and the track to electrical Earth ground.
    When finished, remove the grounding connections.
    You're welcome.
    Master Po - "Accept the ways of others, respect first your own"
  21. The Following 10 Users Say Thank You to Nskale For This Useful Post:
  22. #13
    Apr 2019
    Fair enough. What came of it was a working solution and ballast that laid down properly, so it worked for me. I'll go with real world results over theory every time.
    Besides, did you miss the important part of having the track smell laundry fresh?
  23. The Following 10 Users Say Thank You to Vegaman Dan For This Useful Post:
  24. #14
    255 Post(s)
    I liked that part! Goodness knows the layout room could use a bit more, uh, genteel ambience?
  25. #15
    46 Post(s)
    Ground straps is real world results. That's why the entire electronics industry uses ground straps ...
  26. #16
    289 Post(s)
    IF you believe you have problems with static electricity while doing your ballast then ballasting is the least of your problems:
    Electrostatic Discharge or ESD is an important issue in the electronics industry today. The integrated circuits used to create DCC Decoders and other items are sensitive to static electricity, and can be damaged or destroyed by a static electricity discharge.
  27. The Following 5 Users Say Thank You to wombat457 For This Useful Post:
  28. #17
    Feb 2021
    Cowichan Bay, Vancouver Island, B.C., Canada
    Being new here, I thought that the "genteel ambiance" was created by the beer, ale or single malt.
    Monopoly & Octopus (modified & expanded)
    https://www.nscale.net/forums/showth...R-Layout/page2
  29. The Following 4 Users Say Thank You to Stu For This Useful Post:
  30. #18
    255 Post(s)
    Quote Originally Posted by Stu View Post
    Oh, you're fitting in quite well already!
  31. The Following 2 Users Say Thank You to The Ol' Curmudgeon For This Useful Post:
  32. #19
    151 Post(s)
    I'll raise a glass to @Stu!
  33. The Following User Says Thank You to el Gato Gordo For This Useful Post:
  1. N Scale Laser electricity tower
    By Slamdunk in forum Product & Service Announcements
    Last Post: 19th Nov 2019, 08:53 AM
  2. Replies: 1
    Last Post: 11th Oct 2015, 01:56 PM
  3. Electricity and me Don't get along Help !!
    By Freighttrain in forum General Wiring
    Last Post: 27th Oct 2014, 08:19 PM
  4. ARRRGH! Epic DCC Fail! [Solved!]
    By MetroRedLn in forum DCC
    Last Post: 16th Jan 2013, 07:49 PM
  5. Replies: 14
    Last Post: 25th Oct 2011, 11:31 PM
