Results 1 to 16 of 16
Thread: Whatís your favorite code 80 flex track and why?
    Surprise, AZ
    Default Whatís your favorite code 80 flex track and why?
    Iím in the process of designing my layout. I will be using Kato Unitrack and some version of flex 80. Iím stumped on what brand to get. Ideally one that doesnít oxidize very fast. This is why I am calling on the folks here to help me figure this out.
    1975-present Alaska, BNSF, UP Also 1880-1890 Era
  2. The Following User Says Thank You to Ken B For This Useful Post:
    103 Post(s)
    Quote Originally Posted by Ken B View Post
    Ideally one that doesn’t oxidize very fast.
    Eventually they all oxidize but Kato Unitrack has some secret sauce in their metallurgy that makes them oxidize less. But some don't like their built in "ballast" and the cost.
    At the end of the day it's a personal preference and availability depending on where you live.
  4. The Following User Says Thank You to kingmeow For This Useful Post:
    151 Post(s)
    For me, Peco. I run modern European trains, so concrete ties are a necessity.
  6. The Following 2 Users Say Thank You to el Gato Gordo For This Useful Post:
    Oct 2017
    Galati, Romania,
    45 Post(s)
    Atlas code 80. I have on my diorama, not any traces of oxidation on it. But my diorama is stored in enclosed space. I clean it just for fun, 3 times on 10 years. I have a layer o Aero-Car conducta lube and is work for me. I intend to switch on code 55 next layout.
    I LIKE TO WORK WITH BIG SHIP ENGINES BUT I SPEND MY FREE TIME AROUND N SCALE TRAIN MODELS.
  8. The Following 2 Users Say Thank You to gamitzu For This Useful Post:
  9. #5
    Mill Bay BC
    143 Post(s)
    For me its Peco C80
    I like how it bends and it just works for me
  10. The Following 2 Users Say Thank You to aflica For This Useful Post:
  11. #6
    Aug 2020
    Burton-upon-Trent England
    Peco, although I would go code 55. The visible portion is code 55, however the rail used is code 80 and it fits easy to over code 80.
  12. The Following User Says Thank You to Foxborough For This Useful Post:
  13. #7
    Austin, MN USA
    A lot of the Atlas flex track/sectional track on my current layout is over 45 years old and it sat for four years in my apartment, unused. When I moved the layout here to the house, a few laps around the mainline and the trains ran perfectly fine.
    With most quality nickel silver rail, even though nickel silver rail does oxidize, the oxide is at least partially conductive and wears off with the passage of trains.
    Doug
    Atlas First Generation Motive Power and Treble-O-Lectric. Click on the link:
    www.irwinsjournal.com/a1g/a1glocos/
  14. The Following 4 Users Say Thank You to Doug Gosha For This Useful Post:
  15. #8
    289 Post(s)
    Peco without a doubt.
  16. The Following 2 Users Say Thank You to wombat457 For This Useful Post:
  17. #9
    112 Post(s)
    Unitrack is now making their own flex track. Or has been for a while and is now marketing it in the US, I'm not sure which. I have no experience with that however.
    If not that - Peco. The tie spacing is similar to Unitrack, so the transition will stand out less. If the flex track is for sidings or spurs that might be lighter rail in the real world, you might even experiment with Peco code 55. It's made differently than most code 55 in that it is basically code 80 rail, with a different profile, and buried deeper in the ties. I haven't tried this, but I would think it would match up well with the code 80 Unitrack and give you an option for lighter rail for spurs and such.
  18. #10
    Nov 2011
    DFW Area, Texas
    I'm using Atlas C80 flex track and sectional that I bought in 1997 in my latest layout. I haven't had any issues with it.
    ~Neil
  19. The Following 2 Users Say Thank You to ndronet For This Useful Post:
  20. #11
    Bozeman,MT
    I've always liked Atlas, mostly because it matches US tie spacing better than Peco, but also because I can get it locally. Currently using code 55 Atlas, again because of availability, but also because Peco isn't true code 55. Not much known on the Kato at this point, but here's the link https://www.katousa.com/N/Unitrack/flexible.html
  21. The Following User Says Thank You to MRLdave For This Useful Post:
  22. #12
    Dec 2008
    Redmond, WA - USA
    +1 for Peco C80. I used that on two layouts and I've been very happy with it. As others said, Peco C55 is essentially a double-flanged C80 rail buried in the ties. Even though the rail is C80, the visible rail height is C55. Also, the double flange design allows you to use regular rail joiners to connect it to any C80 rail (like UniTrak)
    Can't do much about oxidation. Track cleaning cars, NOOX, good power feed principles all help mitigate it.
    Serdar
  23. The Following User Says Thank You to ssoysal For This Useful Post:
  24. #13
    May 2005
    Cambridge, New Zealand
    36 Post(s)
    FWIW: Peco every time. I've used it for over 40 years and although during that time I DID try other brands (though only when I couldn't get Peco), these were never as good, and were invariably replaced by Peco when that brand became available once more.
    Thanks for asking.
    Komata "TVR - serving the Northern Taranaki . . . "
  25. #14
    Nov 2019
    Sherwood Park, Alberta
    Kato’s flex track should be the same metallurgy and it’s pretty cheap. I get most of my Kato stuff from a store in Japan, 10pc of flex track is $26 US although I haven’t tried it myself
  26. #15
    Surprise, AZ
    Quote Originally Posted by Intarsiabox View Post
    I haven’t been able to find a source for Kato flex. Could you PM me the link to your source?
  27. #16
    Nov 2019
    Sent you a PM
  28. The Following User Says Thank You to Intarsiabox For This Useful Post:
  1. ME code 55 weathered flex track
    By CraigS in forum Trackage
    Last Post: 3rd May 2016, 09:03 AM
  2. Atlas Code 55 Flex Track W/PECO Code 55 Turnouts
    By I Remember Steam in forum Trackage
    Last Post: 23rd Apr 2016, 11:00 PM
  3. Atlas Code 80 Flex Track
    By Chicago Rail in forum Trackage
    Last Post: 12th Feb 2013, 02:19 PM
  4. Joining Atlas code 80 flex track.
    By BryanC (RIP) in forum Trackage
    Last Post: 10th Jun 2007, 07:07 PM
  5. Replies: 4
    Last Post: 4th May 2006, 07:45 PM
