Results 1 to 3 of 3
Thread: Paragon 4 Decoder Issue
    Oct 2013
    NH, USA
    Default Paragon 4 Decoder Issue
    I finally had time to test out the BLI F7 A/B units I received last week. After cleaning the programming track (it was apparently very dirty after over a year sitting unused), I was able to program both units. The B unit went very smoothly and works fantastic (on also cleaned track.) The A unit also works great but I have one oddity. While I was able to program it successfully. my NCE system will not read the long address on the programming track. I was still able to get it to accept the long address I wanted and it responds properly to that address on the main. But I cannot read it back on the programming track. Other CVs read back fine almost all the time now that the programming track has been thoroughly cleaned. But the long address is 100% consistent in not being able to be read back. I suppose it doesn't really matter since it accepted the address and responds to it. But it bugs mean that it consistently cannot read just the long address back.
    I am curious if anyone else has hit something like this.
    Thanks,
    -Ed
    Northern New England Scenic Model Railroad - N Scale early fall in NH in the mid-1950s.
    https://nnescenicmodelrr.com/index.php
    Sep 2019
    South Mississippi, USA
    68 Post(s)
    Hello Ed
    I have a pair of the Paragon 4 SD40-2’s. Although I am running Digitrax, I haven’t come across this issue with my locomotives. I too have put them back onto the test track and all appears normal. I am just wondering if it could be your NCE system itself? Have you tried reaching out to BLI? Because the programming issue could be anything from the incompatibility(which I doubt) with the NCE or maybe the decoder itself? Have you tried doing a factory reset on the decoder?
    Clayton
    Oct 2013
    NH, USA
    I found some references online to the NCE program track sometimes having trouble reading back with certain sound decoders due to the power draw of those decoders. But as long as it has taken the values input I am fine. I am starting to use ops mode programming more anyway.
  4. The Following User Says Thank You to edfhinton For This Useful Post:
  1. Paragon decoder
    By TVRR in forum DCC
    Last Post: 21st Aug 2021, 10:56 AM
  2. MRC decoder issue
    Last Post: 4th Apr 2021, 05:15 PM
  3. Kato F7B / Digitrax decoder issue
    By OTFan in forum DCC
    Last Post: 16th Mar 2020, 05:36 AM
  4. Replies: 15
    Last Post: 27th Jun 2018, 11:04 AM
  5. TCS decoder speed issue
    By Lagerstout in forum DCC
    Last Post: 30th Jan 2016, 12:52 PM
